manual pcm
Old Nov 18, 2011 | 09:14 PM
jg96powerstroker's Avatar
jg96powerstroker
manual pcm
hey guys trying to find a manual pcm, after my auto to man swap with my chip to fool pcm i have no cruise and miss it... thankks guys
Old Nov 19, 2011 | 03:13 AM
DRRXR's Avatar
DRRXR
This may intrest you
https://www.ford-trucks.com/forums/1...e-control.html
Old Nov 20, 2011 | 09:04 PM
redman84's Avatar
redman84
Hey Jason. I had my auto PCM reburned which is essentially what you've done with your chip. With the help of several high caliber guys I was able to figure that same issue out. After the swap I ran it stock for a while and my cruise worked but when it was reburned as a manual my cruise stopped functioning correctly. I was given some good info on this subject from Jody Tipton and Jim Rose and got it working again. Here's the scoop:
I spliced Pin 29, the Tan/WH wire, into Pin 31 which is Black/Yellow. Pin 31 is the brake pressure switch and my diagram shows it to be hot always EXCEPT when the brake is applied. Anyway, took it for a test drive afterward and everything works as it should, all the cruise controls and brake disengage. I heard indirectly from Ryan Bean that you just have to verify 12v to Pins 29, 31, and 92 and as long as those check out it will work.
jbas
Sep 19, 2016 11:34 PM
redman84
Jan 24, 2012 01:46 PM
BRONCOPASSION
Sep 21, 2011 09:20 PM
redman84
Jun 17, 2010 08:47 PM
Supertrey
Mar 10, 2010 10:45 AM
