Looking for advice on Evans NPG vs Red ELC coolant
Old 11-19-2011, 05:46 PM
cutlass's Avatar
cutlass
cutlass is offline
If I'm filling the system up from being completely dry, how much 50/50 mix coolant do I need?
Drake
Old 11-19-2011, 05:50 PM
cj45lc's Avatar
cj45lc
cj45lc is offline
I believe it takes 8 gal
Old 11-19-2011, 06:10 PM
cutlass's Avatar
cutlass
cutlass is offline
When getting ELC OAT coolant, does it say "OAT" anywhere on the bottle?
Drake
Old 11-19-2011, 06:15 PM
cj45lc's Avatar
cj45lc
cj45lc is offline
It should be on the jug some where, might be on the back
I got the Cat stuff & do remember reading the OAT on there
Old 11-19-2011, 08:42 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Drake
It might on the back somewhere, but just look for the Cat EC-1 compliance in conjunction with "Extended Life Coolant" print on the bottle.
Some brands will also say on the bottle "SCA not necessary"
Chevron Delo ELC looks like this:
Stewart
Old 11-20-2011, 04:08 PM
AMG-SM's Avatar
AMG-SM
AMG-SM is offline
I have used Evans on one of my turbo charged track cars. It has some benefits on cars whose coolant systems are "challenged" to keep up with extreme situations since it doesn't boil and can be run at 0 pressure. Overall, I don't think its worth it for a PSD. The coolant system on these trucks seems to work well.
I did blow a hose once on that car while using Evans. I made an emergency repair to the hose and topped off with distilled water to make it home. Flushed it all out after that and went with cheaper, readily available distilled water and coolant.
Old 11-21-2011, 04:35 PM
trekbasso's Avatar
trekbasso
trekbasso is offline
Wow! Thanks for all the very timely info, especially the link to the coolant info. Almost too much. I am thinking of a coolant change this weekend. It has very green coolant.
So, I bought my truck with 191k, has 203 now. Previous owner had for 50k, 5 years. He did not remember doing the water pump.
How would I know if it has been changed, and what is the recommended change interval?
Thanks.
Tom.
Old 11-22-2011, 11:57 AM
txgp17's Avatar
txgp17
txgp17 is offline
I just replaced the water pump on my 02' 7.3 last week. I made the switch to Evans NPG+. I bought another radiator cap and gutted the internals to make it zero pressure. I wish someone would make a low-pressure cap the the 7.3. I'd like to have a little pressure, maybe 2 psi.
The motor has 280,000 on it. I'll report back if there's any problems.
Old 06-02-2013, 02:04 PM
txgp17's Avatar
txgp17
txgp17 is offline
Just a followup, I had to replace the water pump again this week. 299,000 on the odometer. So a new NAPA water pump only lasted 19,000 miles.
Maybe the zero pressure cap had something to do with it, not pushing coolant far enough into the assembly.
Old 06-03-2013, 12:02 AM
caedo's Avatar
caedo
caedo is offline
Interesting
Old 06-03-2013, 02:08 AM
Stewart_H's Avatar
Stewart_H
While I know the cause of the pump failure could be a few different things, it is anecdotal evidence such as this post, that caused me to post what I wrote in post #2 above.
Originally Posted by Stewart_H
Evans is good stuff, but in my opinion, not for the 7.3L PSD.
Our trucks were engineered to run a pressured cooling system. The water pump was engineered to perform that way. Evans is a pressureless system and while I haven't seen any proven data, there has been speculation that our water pumps don't perform well when it comes to circulating the Evans in an optimum manner.
Stewart
Stewart
Old 06-03-2013, 05:24 AM
dn29626's Avatar
dn29626
dn29626 is offline
I am not a fan of NAPA but i do buy my ELC diesel coolant (Zerex) from them.
  #28
Old 06-03-2013, 05:57 AM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1 is offline
stinson 108-1
I've been using Evans for a couple years now and it works. Coolant is as clean as it was out of the bottle. It is Not a zero pressure system. I've asked Evans about this and was told to run the stock cap. You CAN run no pressure as it has a higher boiling temp than water, and that may be an advantage for some applications. I bought a 5.00 cap and drilled a hole in it and ran that for a while to get the remaining water out and then put on the stock cap. I like it. No water, no rust, and is supposed to reduce cavitation. In the end, just use the best product available.
jed1894
29
10-15-2022 01:25 PM
superduty91
6.7L Power Stroke Diesel
18
07-01-2015 09:50 AM
Robbgt
04-28-2006 11:43 AM
SpringerPop
10-14-2005 04:45 PM
EBSTEVE
07-28-2005 09:54 AM
Quick Reply: Looking for advice on Evans NPG vs Red ELC coolant
