Fuel pump voltage test.
Old Nov 18, 2011 | 12:51 PM
avproavi's Avatar
avproavi
Can voltage to the fuel pump be read at the output of the cutoff switch to help trouble shoot?
What should it be...........
Old Nov 18, 2011 | 07:31 PM
caseys's Avatar
caseys
xxxxxxxxxx
Old Nov 18, 2011 | 07:46 PM
shorod's Avatar
shorod
Welcome to the forum!
This may be depend on the model year of your truck, possibly even the engine in your truck. Please provide both.
The voltage at the output of the cutoff switch is just that, the voltage at the output of the cutoff switch. There is more wire and more connections between the cutoff switch and the fuel pump, so more opportunities for breaks, corrosion, and other issues. If the wiring is fine between the switch and the fuel pump, then yes, for all practical purposes the voltage out of the switch will be the voltage at the pump.
As for what the voltage should be, that depends on if your particular truck uses a returnless fuel system or not. If it is not a returnless system, then the voltage to the pump should be battery voltage when the engine is running. When the key is turned to Run, the pump should receive battery voltage for a second or two to prime the system.
If the system is a returnless system, then the voltage to the pump will vary depending on the reading from the fuel pressure sensor. The fuel pump driver will use pulse width modulation (PWM) to adjust how much fuel pressure the pump provides to maintain the correct fuel rail pressure.
-Rod
fferd
1997 - 2003 F150
50
Mar 10, 2025 09:16 AM
rshwin
1997 - 2003 F150
Jan 16, 2017 11:34 AM
trat3gic
24
Jun 10, 2016 08:45 PM
jaysonp
Dec 13, 2010 10:41 AM
Rhood
Electrical Systems/Wiring
Nov 1, 2005 09:41 PM
