3G upgrade
Old Nov 17, 2011 | 07:56 PM
Fexx22's Avatar
Fexx22
3G upgrade
I installed the 3g alternator in my truck and i do not have no power to the lights or the ignition switch...what color wires are they and where do they go
Old Nov 17, 2011 | 08:09 PM
HIO Silver's Avatar
HIO Silver
Here are the wiring diagrams:
<A HREF=http://i55.tinypic.com/21jw50l.jpg>74-78 Wiring Diagram Pt1</A>
<A HREF=http://i52.tinypic.com/35luc8n.jpg>74-78 Wiring Diagram Pt2</A>
Old Nov 17, 2011 | 08:47 PM
jsutton's Avatar
jsutton
You probably didn't hook 12 volts to the big black/yellow wire. If you removed all the stock wiring between the original alternator, regulator, and solenoid you unplugged the power to this wire. You need to run a 10 gauge wire or so to the battery side of the solenoid and hook it to the black/yellow.
Its also a good idea to put an 80 amp fuse inline when you run the new section of wire.
This is covered in the "just did 3g upgrade" thread if you need some more info, it may take some looking and reading though.
Old Nov 17, 2011 | 09:09 PM
Fexx22's Avatar
Fexx22
Ahhh yes.....lol....I got it...the info was right on, I took the old harness apart to see how it was wired and by the time i got that done you guys posted...thanks again its running 14.4V
Old Nov 17, 2011 | 09:13 PM
Fexx22's Avatar
Fexx22
I also snagged a power box off a 96 tbird, does anyone know if you can get new crimps for these electrical boxes?
jcormiea
Dec 27, 2017 03:32 PM
1975FordF250
Escape & Escape Hybrid
Jul 27, 2016 09:24 PM
TheRedPheonix
Oct 20, 2012 05:56 PM
ferguson777
32
Jul 7, 2012 06:27 PM
sdetweil
Jun 1, 2006 11:48 AM
