truck bed panel replacement.
Old Nov 16, 2011 | 10:51 PM
ericford1984's Avatar
ericford1984
im thinking of replacing the rusted metal around the wheel wells...but if i cut out the old and weld a new one flush how will i sand the welds that go through and are on teh back side? or should i replace the whole skin on the side and has anyone done that.? the more i can do to keep it cheap the better and any videos or websites on painting and autobody work is awesome thanks!!
Old Nov 18, 2011 | 02:17 PM
UncleShank's Avatar
UncleShank
Originally Posted by ericford1984
im thinking of replacing the rusted metal around the wheel wells...but if i cut out the old and weld a new one flush how will i sand the welds that go through and are on the back side? or should i replace the whole skin on the side and has anyone done that.? the more i can do to keep it cheap the better and any videos or websites on painting and autobody work is awesome thanks!!
I use to work in a body shop. that is the most expensive and most complicated way to do that. can you post some pics to show how bad the rust is? a new side/skin is $1k or more. we use to reside the truck beds of a roofing contractor down in Indianapolis, about once every three months. each time it was both sides and it was about a $10k including parts, paint, and labor(i never did any of it). The cheapest way is probably going to be to grind the rust down and then weld, if you can, a piece of metal to the back side of the skin and then apply bondo to it sand it down and paint it.
Old Nov 18, 2011 | 03:56 PM
tjc transport's Avatar
tjc transport
i ain't rite
what year truck?
it may be easier to just replace the whole bed.
bhalemail
18
Nov 3, 2017 03:06 PM
ericford1984
Paint & Bodywork
Apr 6, 2012 08:27 AM
Riskyguy
Jun 17, 2011 08:06 PM
wintremute
16
Aug 7, 2006 07:01 AM
gearbot
Paint & Bodywork
Apr 10, 2005 01:35 AM
