clicking
Old Nov 16, 2011 | 04:13 PM
jonjanke's Avatar
jonjanke
clicking
I have a 2003 expedition and when the rear air/vent is turned on i get a clicking noise from the rear right interior side of the vehicle. When I turn up the temp **** to a warmer setting the noise goes away. Any thoughts. Thanks in advance.
Old Nov 16, 2011 | 05:26 PM
alloro's Avatar
alloro
A gear inside the blend door motor assembly has stripped some of it's teeth. You can't get just the gear, you have to replace the motor assembly.
Old Nov 16, 2011 | 07:09 PM
alwaysfords41's Avatar
alwaysfords41
Does it go away when you switch from floor to ceiling or when you change the temp? The first actuator is easier to change than the latter. Search blend door actuator here and you will find directions.
bgwho922
Jul 9, 2017 12:25 PM
meborder
21
Aug 28, 2014 10:57 AM
jjkreger
Jan 22, 2013 09:17 AM
MikeyG123
15
Jul 10, 2010 01:52 PM
honkydog
1997 - 2003 F150
Dec 8, 2009 09:00 PM
