Water problems
Old Nov 16, 2011 | 08:02 AM
alexisvfd's Avatar
alexisvfd
Water problems
I got a 02 f350 and everytime it rains and I'm driving it starts to jerk. Just when it rains that's it. I don't know what could cause that. Any ideas
Old Nov 16, 2011 | 10:29 AM
alexisvfd's Avatar
alexisvfd
It only jerks when it's raining and it don't matter if it's hot or cold
Old Nov 16, 2011 | 11:53 AM
ccerniglia's Avatar
ccerniglia
You need to better explain this "jerk" motion. Does it happen at an idle/low speed? You need to help us on specifics. First we need to know if its an engine "jerk" or something steering/suspension.
Old Nov 16, 2011 | 02:16 PM
alexisvfd's Avatar
alexisvfd
It's the motor. It's like it quits firing the starts back and jerks. When I'm idling it will cut off and start right back up. But it only does it in the rain that's y I don't think it's the ficm or injector.
Old Nov 16, 2011 | 02:36 PM
ccerniglia's Avatar
ccerniglia
Oh, its a 7.3L. We'll i'm sure a code got stored in the PCM since the last time it happen, run it to autozone and see if they can get anything with there scan tool. We here on the forums are going to be very limited with our Diag. Could be a crank sensor or ICP.
Old Nov 16, 2011 | 02:58 PM
alexisvfd's Avatar
alexisvfd
When it cuts off it throws a code but when u cut it off and back on it clears it. Had it plugged up 7 times in the past 2 weeks. I don't know it's weird
Old Nov 16, 2011 | 04:38 PM
BigAlsPSD's Avatar
BigAlsPSD
Sounds like a CPS failure, or more likely a seal issue for the CPS, Which CPS do you have installed? Have you had the recall done, if not Ford will change the CPS free. Should be around $25 if you need to purchase one, do not get one from the parts houses the ones from the parts houses, do just what you describe...wiper motor interferes with the signal.
If there was a SES light turning the key off will not clear the code stored. Most OBDII readers at the parts stores will not read Powerstroke specific things.
Old Nov 16, 2011 | 07:53 PM
alexisvfd's Avatar
alexisvfd
I didn't never hear of the cps but I researched it. I'm gonna call and get a price. Is there anything else that could cause that. What gets me is that it only does it when it rains. Like something is getting wet and shorting out. It's weird to me
Old Nov 16, 2011 | 08:04 PM
BigAlsPSD's Avatar
BigAlsPSD
That's even more the reason for my thoughts on the CPS. Search the www.ford-trucks.com/forums/forum31/
Old Nov 16, 2011 | 08:14 PM
alexisvfd's Avatar
alexisvfd
Where is it located and are u saying that that's the way it would run if it's going bad
Old Nov 16, 2011 | 08:20 PM
BigAlsPSD's Avatar
BigAlsPSD
It is located about 11 o'clock on the Harmonic balancer, you would need a 10MM wrench or socket 6 point to remove the bolt, then it pops out.
Welcome to guzzle's CPS R&R Web Page<
Old Nov 16, 2011 | 08:44 PM
alexisvfd's Avatar
alexisvfd
Does that sound like the problem to you. The part where only when it rains is what gets me
Old Nov 16, 2011 | 08:57 PM
BigAlsPSD's Avatar
BigAlsPSD
To me it's worth a $25 gamble, every owner I know of a 7.3 keeps a spare CPS in their glove box. I have 3, don't know why, maybe someone broken down on the side of the road who wished they had one needs it.
Here's a thread on wipers interfering https://www.ford-trucks.com/forums/7...to-hiccup.html
Another
https://www.ford-trucks.com/forums/8...ck+dies+wipers
Another
https://www.ford-trucks.com/forums/7...ck+dies+wipers
Pages of them in the 7.3 forum.
Old Nov 17, 2011 | 07:39 AM
ccerniglia's Avatar
ccerniglia
Crank Sensor Part# F7TZ 12K073-B Ford List: $23.20
Old Nov 17, 2011 | 08:52 AM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
