7.3 no start
Old Nov 15, 2011 | 08:44 PM
bigbubba87's Avatar
bigbubba87
7.3 no start
Ok guys my brother is still having problems with bus truck. It still won't start. Can someone give me a simple rundown of what a 7.3 needs to start. And how to test it. Thanks Justin
Old Nov 16, 2011 | 05:58 AM
427 fordman's Avatar
427 fordman
What have you done? It needs at least 500psi of high pressure oil to fire the injectors, scanner or a mechanical gauge hooked up to see this. Needs fuel pressure and lots of electrical things can go wrong.
Need more info.
Old Nov 16, 2011 | 08:21 AM
scottjbear's Avatar
scottjbear
Diesels are not the same as they use to be. Before there was 3 three simple things..1)compression, 2) fuel, 3)air.. Now you need oil to the injectors and you have individual injectors that can have all sorts of issues but always start with the basics. the compression I would wait for after you check the others.
Old Nov 16, 2011 | 08:35 AM
bigbubba87's Avatar
bigbubba87
I messed with it a little but not much cuz the pcm that was in the truck was supposedly bad. He put a new pcm in it. Tach moves while cranking, no wts light, faint smoke out the exhaust. I'm going home next week and going to work on it just want to get a good place to start and know exactly what all tests I have to do. I have all tools needed minus a scan tool.
Old Nov 16, 2011 | 08:44 AM
bryanlindborg600's Avatar
bryanlindborg600
Check fuse 22 under the hood, no wait to start light means no Power to the PCM. Fuel bowl heaters are known to cause this problem.. Hopefully a new fuse and possibly unhooking the fuel bowl heater will get him back up and running! Where did the new PCM come from? Are you sure it is the correct code for the truck? There are a couple different things that will effect a PCM working between trucks..
Old Nov 16, 2011 | 10:13 AM
bigbubba87's Avatar
bigbubba87
Well he just had the pcm flashed. and is there a fuel pump in the tank? Checked fused and unplugged the fuel bowel heater still no start.
Old Nov 16, 2011 | 10:33 AM
Hussler's Avatar
Hussler
1. Truck need to sense RPM and cylinder ID (CPS).
2. Truck needs fuel pressure, >= 20 PSI while cranking.
3. Truck need ~ 500 PSI HPO before PCM instructs IDM to fire injectors (ICP - IPR).
If getting some smoke then injectors are firing and criteria 1 and 3 are being met. Check fuel pressure and make sure screen (inside fuel canister) is clean as that vents air from the fuel.
Worried about no WTS light as that usually indicates a fuse (can't be because you have RPM on tach) or bad PCM.
Old Nov 16, 2011 | 12:04 PM
bigbubba87's Avatar
bigbubba87
does the pcm need to be recalibrated after its flashed?
Old Nov 16, 2011 | 12:51 PM
Hussler's Avatar
Hussler
No, it would have to relearn strategy as if you disconnected the batteries.
Old Nov 16, 2011 | 06:56 PM
bigbubba87's Avatar
bigbubba87
Ok well my brother said someone told him it needed calibrated for his truck. I just wanted to see if he was right or not.
carltonwebb
Nov 8, 2024 09:42 PM
Nsmock
44
Feb 10, 2019 01:56 PM
Little33456
Oct 24, 2018 06:21 PM
GeorgiaBoy17
22
Feb 19, 2014 09:00 AM
2000ca250
46
Jan 7, 2012 03:57 AM
