V codes verses X codes
Old Nov 15, 2011 | 06:58 PM
LivingLarge's Avatar
LivingLarge
Hi Guys, I just installed the RAS and at the lowest setting I got an inch lift.
Now i'm looking to raise front about 1.5 inches. Was thinking of replacing my V-codes for X-codes.
At that point I would also go from my 285's to 315's.
Also looking for Ford part numbers for X-code.
All opinions are welcome, and thanks in advance for your replies,
Michael
Old Nov 15, 2011 | 09:14 PM
njneer1's Avatar
njneer1
You will need more than 1.5 inches on the front to run 315's....you might get 305's on it.
Old Nov 15, 2011 | 10:23 PM
LivingLarge
1.5 inches more than my V-codes should do it. x-codes on v10 should be 3 inches over stock.
Old Nov 16, 2011 | 12:05 AM
Sparky04SD's Avatar
Sparky04SD
I have 4" all spring lift and 315's rub on 16x10" rims. I can't see how anyone expects to run 315's without rubbing on 2-3" of lift. My stock F250 ran 315's on 8" rims and rubbed. I went to 4" blocks and a Edge mini spring pack for an additional 1.5" of lift and barely clear enough not to rub. 305's are the biggest you can run, safely.
Old Nov 16, 2011 | 02:36 AM
JohnnyAirtime's Avatar
JohnnyAirtime
I've been running a 3" shackle kit up front, and 315s all day long.
... and it's a PSD (heavier)
However, on the stock wheel... it'll rub heavily on the leaf spring at full lock. And even with a 8.5" wheel, it rubs, and does so a tad bit on the inner fender well when I'm at full lock and the suspension cycles a tad bit.
So sure it rubs, but nothing like it's tearing inner wheel wells apart. I ended up using large zip ties to pull the wheel well away from the tire, and it's worked great for a long time.
Old Nov 16, 2011 | 06:32 AM
locknload223's Avatar
locknload223
Agree'd with the rest, I think you're going to need more than X codes to run 315s. I was rubbing on hard lock with my 4" hanger and stock springs. Granted they were pretty worn out but you get the idea. Add a small 2" hanger to X codes, or save some coin and add a 4" to your V codes. Are they new spring packs? Hate to see you start all over money wise.
Old Nov 16, 2011 | 07:01 AM
wpnaes's Avatar
wpnaes
In case a photo would be helpful... Front passenger side tire: 305 in the first pic vs. 315's in the 2nd.
Old Nov 16, 2011 | 04:57 PM
bigwhitetruck01's Avatar
bigwhitetruck01
Well if you decide to swap out those V's for something else i'd be interested in taking the V's off your hands.
Old Nov 17, 2011 | 11:26 AM
LivingLarge
Mike, when you get the chance can you post a pic of your Hanger and lift size. If i recall, you do not know the brand?
If i go the hanger way, i would probably keep the V-codes.
Thanks
Old Nov 17, 2011 | 11:29 AM
LivingLarge
Sean, Thanks for the pics. The 315's look great! What do you have in the rear, as far as lift?
Michael
Old Nov 17, 2011 | 11:36 AM
locknload223
Here's the only pic I have of the 4" hanger right now, not sure what brand it is. It was installed by the PO.
Old Nov 17, 2011 | 11:48 AM
locknload223
Ya know, now that I look at mine and others, I wonder if mine is a 2" hanger? It kind of looks like it. I'll do some measuring when I get home. The PO said it was a 4" and it sounded right because it had 315s on 10" rims.
NOW, I wonder...
Old Nov 17, 2011 | 11:57 AM
LivingLarge
Mike, the rear on your truck looks about level, do you only have the 350 blocks on there?
Old Nov 17, 2011 | 12:12 PM
locknload223
Yeah the tapered F350 blocks.
Funny, I googled '4" hanger kit excursion' and there's four pics of my truck on page 1 and one pic of my old F250 on page 2.
I'm SOMEBODY!!
Old Nov 17, 2011 | 12:15 PM
LivingLarge
I'm SOMEBODY!!
Yes you are!!
