Back With a '66!
Old Nov 27, 2011 | 03:40 PM
shanesdentist's Avatar
shanesdentist
Thanks for the tips. I think things just got worse. I ran the truck for a while trying to figure it out. While it was running the was an obvious lifter ticking. Then it stopped...
The ticking was replace with the sound of something bouncing around under the valve cover. I stopped the engine and pulled off the cover. underneath I found some hard pieces of plastic. I'm thinking it is an old brittle valve seal.
I've searched and have found replacements pretty cheap but always seem attached to a rebuilding of the head. Is it possible to replace these guys without removing the head?
Old Nov 27, 2011 | 08:01 PM
bunchoftrucks's Avatar
bunchoftrucks
I really can't tell what it is that you've found by the pic's.
Old Nov 28, 2011 | 10:50 PM
frty7ford's Avatar
frty7ford
it is possible to change them without pulling the head. You will need a valve spring compressor similar to this one Lisle 16750 Valve Spring Compressor. an air compressor and an adapter to put air through the spark plug hold. some compression testers have come apart and that works. bring the cylinder to the top of the compression stroke put air to the cylinder. This will hold the valve up when you are working on it. Use the compressor pull the keeper and spring replace the seal. good luck
yankbs 66f100
107
Mar 3, 2017 05:18 PM
Custom66Cab
Apr 22, 2013 02:18 PM
WaltherP99
Nov 28, 2012 06:36 PM
Old_Ford_Man
Texas Chapter
32
Apr 25, 2011 04:03 PM
RJP66F100
34
Dec 24, 2010 08:31 AM
