EOP
Old Nov 15, 2011 | 01:06 PM
EXbowtieguy's Avatar
EXbowtieguy
EOP
Well as some of you know I had 1 grenade on me , replaced it , 350 miles later this ones pumping oil out of the connector again ?????
Ford OEM part , just home off of a 300 mile trip , cruise control on 70 the whole way, all readings on the Insight CTS perfect , with oil pressure never getting over 70-75 psi?
I'm a little frustrated !!! Any help appreciated?
Old Nov 15, 2011 | 01:07 PM
EXbowtieguy
Most of the trip the oil PSI was right around 45-50 if it helps ?
Old Nov 15, 2011 | 02:38 PM
EXbowtieguy
Bump.... What are the odds of getting a bad one to replace a bad one ?
Old Nov 15, 2011 | 03:08 PM
EXbowtieguy
Would some type of electrical short cause it to fail/leak ? The single wire into the connector looks a little banged up ?
Old Nov 15, 2011 | 03:22 PM
dchamberlain's Avatar
dchamberlain
Something is a little confusing. The engine oil pressure switch is just a switch. It doesn't read oil pressure. It switches on and moves the oil pressure gauge up at about 7 PSI, and switches off and drops the gauge to zero below 7 PSI. And I don't think a new one should start leaking right off again.
What are you reading oil pressure with on the Insight?
Old Nov 15, 2011 | 03:30 PM
Nice Work Truck's Avatar
Nice Work Truck
The CTS reads oil psi ?
My CS doesn't !!!
Old Nov 15, 2011 | 03:32 PM
dchamberlain
The CTS can't read oil pressure. Unless there is a way to add an external oil pressure sensor. That was the whole point of my question.
Old Nov 15, 2011 | 03:41 PM
EXbowtieguy
Add on (AES) pressure sensor mounted into a bung welded into the oil filter housing. You can "daisy chain" as many pressure or temp sensors as you want I believe ?
Old Nov 15, 2011 | 03:43 PM
Nice Work Truck
It would be great if the is an aftermarket sensor we could add.
Oil psi is the one thing the I can not read and would like to.
Old Nov 15, 2011 | 03:44 PM
dchamberlain
So which oil sensor is leaking. The stock oil pressure switch, or the oil pressure sensor you have added on?
Nice Work Truck
Do you have a link for them ?
Old Nov 15, 2011 | 03:47 PM
EXbowtieguy
Old Nov 15, 2011 | 03:51 PM
EXbowtieguy
The factory oil pressure switch (mounted in the oil cooler housing) Ford part # F81Z-9278-AA
Old Nov 15, 2011 | 03:53 PM
Nice Work Truck
Great, Thanks.
You probably could get a new oil cap with the port in it for that also.
dchamberlain
I don't think it should fail so quickly, unless you somehow damaged it putting it in. It does not need to be very tight.
I think I would take it out and see if they'll warranty it at the parts counter.
