E4OD fluid any recommendations?
Old Nov 15, 2011 | 11:49 AM
Midnite1987's Avatar
Midnite1987
Ok well I'm picking up a new filter from for to hopefully fix my tranny issues. What ATF fluid do you guys recommend? I know it calls for mercron. The ford dealers all have the mercron v fluid but said the v isn't needed just mercron. So any brand or whatever recommendations? I have quakerstate dexron/mercron at in there now that is about a month old from when I changed the filter and installed my shift kit but used an aftermarket filter and have been having stalling issues lately and getting a ford filter is the only thing I haven't done that has been suggested to me yet.
Should I just Re use the fluid?
Any suggestions would be great...
Old Nov 15, 2011 | 12:44 PM
Lazy K's Avatar
Lazy K
When you changed the filter one month ago did you change all the fluid or just what was in the pan?
Old Nov 15, 2011 | 04:32 PM
Midnite1987
I drained te pan and I had the valve bodies out of it so in thinking I got most of it. The fluid in it now is a nice red still not dark
Old Nov 15, 2011 | 04:43 PM
Lazy K's Avatar
Lazy K
You would not have got the most of it out. Probably only around 7qts of the 16qts that are in there. So I think I would discard the fluid you are now going to drain (probably 5-6qts) and add new Dexron/Mercron spec fluid. That would mean that you would have changed a fair part of the fluid.
Old Nov 15, 2011 | 07:13 PM
86F150302's Avatar
86F150302
Torque converter holds The rest of the 16-18 quarts total.
Do not use mercon V fluid ever in an E4OD UNLESS its ford mercon V its compatible with the merc/dex.
But trans fluid brands are just like oil brands. Everyone has their opinions.
I personally will be swapping to tractor hydro fluid in my trans. Synthetic is too expensive for 18 quarts for me.
If your fluid is new and looks good just reuse it.
Old Nov 15, 2011 | 08:06 PM
Midnite1987
I just picked up the ford filter...$75?!?!? Holy crap!!
Well I guess when I drop my pan If my filter is sitting in the pan the ford one goes in. Hell I'll throw the ford one in anyways..... I hope it fixes my damn issues
Old Nov 16, 2011 | 02:21 AM
rla2005's Avatar
rla2005
Cut from this thread on another forum ( E4OD Diagnosis Thread - FSB Forums )
My truck wants to stall when put in reverse
This may or may not be accompanied by irraddic idle and/or codes. If no codes are found pull the IAC (Idle Air Control) sensor and clean/replace as needed.
Here is an IAC cleaning writeup
http://www.fullsizebronco.com/forum/...t=IAC+cleaning
Another potential problem is that the transmission filter may have dropped into the pan. This is easy enough to fix. Remove pan, reinstall filter, fill with fluid.
There is a clip made that will help hold the filter in place since from the factory the filter is only held in by the o-ring. Look 3/4 of the way down this page.
E4OD, 4R100 Transmission from PATC, E4OD, 4R100
It looks like this:
There is also a magnet from Ford that works as a filter retainer. p/n F3RZ-7E290-AC
http://web.archive.org/web/200107271...in.asp?num=037
Old Nov 16, 2011 | 06:15 AM
Midnite1987
I have already removed cleaned and tested the IAC valve it appears to be good.
I cut the wire for the tc lock up to see I'd it was locking up no change
Fluid level is good.
Going to test TPS before I drop tranny pan tho.
Old Nov 16, 2011 | 07:09 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
what makes you feel your engine stall is not engine related,but transmission related instead?
please post your source as to why Mercon V fluid by other brands meeting Mercon V specs is inadequate.
Old Nov 16, 2011 | 09:29 PM
Midnite1987
It started stalling only when shifted into reverse at first. Then drive and reverse and now even when I stop at a light. The motor hasn't given me any issues.
I had installed a b&m stage 2 shift kit prior to any issues and found the shifting to be too harsh for my liking. I dropped the pan and change out the stage 2 springs for the stage 1 springs In the kit.
I had to remove the filter to remove the valve body to change springs. The shifting didn't seem to change much between the different springs. That was all about 2 months ago. The truck is a weekend vehicle so doesn't go far. The truck starts and idles greatin park and neutral. As soon as it go into gear now it stumbles and dies.
A few guys have said if the filter falls out of place it can cause this issue.
Do you have any other suggestions I should look at before I put another 75$ filter in the tranny if it isn't the problem?
I was thinking possibly TPS?
The IAC tested good.
Motor has recent 6liter tune up as well.
Old Nov 16, 2011 | 09:36 PM
Midnite1987
And there are no codes KOEO or KOER
My speedo and odo both work as well so that "should" rule out the VSS I would think
Old Nov 16, 2011 | 09:54 PM
blkF250HD's Avatar
blkF250HD
If it's backwards compatible (most new fluids are) you should have no problem running the newest iteration of Mercon. If you have an E4OD there is a TSB regarding this problem.
Article No.
97-15-21
07/21/97
^ STALL - ENGINE STALL DURING TRANSMISSION ENGAGEMENT - VEHICLES EQUIPPED WITH E40D
TRANSMISSION
^ TRANSMISSION - E4OD - ENGINE STALL DURING ENGAGEMENT
LIGHT TRUCK:
1996 BRONCO
1996-97 ECONOLINE, F-150-350 SERIES,
F-53 MOTORHOME CHASSIS
1997 EXPEDITION
1998 NAVIGATOR
ISSUE:
Some vehicles may stall when the transmission is placed into gear. This may be caused by the transmission fluid filter becoming detached and/or loose.
ACTION:
Install a rectangular fluid pan magnet under the transmission fluid filter to keep the filter in place and reduce the possibility of the filter becoming loose. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Follow all the normal diagnostic procedures outlined in the appropriate model/year Service Manual. Repair as required. If all normal diagnostics fail to correct the problem, refer to the following Steps.
1. Remove the transmission fluid pan to determine if the transmission fluid filter has dropped down or is not firmly seated in the pump bore.
2. If the filter is not firmly seated in the pump bore or falls down into the fluid pan when the pan is removed, place the rectangular Transmission Pan Magnet (F3RZ-7E290-AC) on the pan at the location shown in Figure 1.
NOTE : DO NOT REMOVE THE ORIGINAL FLUID PAN MAGNET FROM THE FLUID PAN OTHER THAN TO CLEAN AND REINSTALL.
CAUTION : DO NOT USE THE ORIGINAL FLUID PAN MAGNET TO HOLD THE FILTER IN PLACE. IT IS TOO THICK AND MAY CAUSE A LEAK.
3. Install a new Filter and Seal Assembly (E9TZ-7A098-A).
CAUTION : DO NOT REMOVE AND REPLACE THE REUSABLE PAN GASKET OR REPLACE IT WITH A CORK GASKET, THIS MAY RESULT IN A LEAK CONDITION.
4. Refill transmission as required using MERCON(R) Multi-Purpose Automatic Transmission Fluid (ATF) (XT-2-ODX).
PART NUMBER PART NAME
F3PZ-E290-AC Transmission Pan Magnet
XT-2-ODX MERCON(R) Multi-Purpose Automatic
E9TZ-7A098-A Filter And Seal Assembly
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
971521A Install New Pan Magnet 0.7 Hr.
971521B Additional Time To Clean, 0.1 Hr.
Inspect, And Reuse
Elastomeric Reusable Pan
Gasket
DEALER CODING
CONDITION
BASIC PART NO. CODE
7A098 33
OASIS CODES: 502000, 503000, 504000, 607000, 607400
Old Nov 16, 2011 | 11:12 PM
Midnite1987
mine doesnt have the rectangular pan magnet. it only had the round one.
so i should pick up a rectangular one and use the magnet with the filter thats in there currently since its only 2 months old? or should i use the other filter i just picked up? id love to save the $70 lol
Old Nov 17, 2011 | 05:01 AM
86F150302's Avatar
86F150302
HOT tranmission - Page 2 - The National Lightning Owners Club Inc
post 20
Old Nov 17, 2011 | 01:24 PM
Midnite1987
I called the local ford dealer o see if I can find the magnet, the ford part number that's on the post above doesn't exist and they don't show the rectangular magnet in their systems....
Tom Evans
Jan 22, 2016 08:41 PM
$undance
1997 - 2003 F150
Jun 27, 2014 12:46 PM
true blue
Jan 15, 2011 09:09 AM
Jason4787
Dec 25, 2003 11:42 PM
rmcn1
Aerostar
Apr 16, 2003 11:51 AM
