bought my first 6.0 need some pointers.
Old Nov 14, 2011 | 06:13 PM
mstiles19's Avatar
mstiles19
well i traded in my trusty 2001 5.4 with over 200k on the clock for a 2004 f250 xlt fx4 6.0 with 84,000 miles and a Manuel transmission. The truck is in very nice shape and seems to have been taken care of very well, that being said what should I do to to this truck to make it last long, as well as some minor performance and mileage upgrades.
My main questions are:
1. erg cooler or delete
2. opinions on exhaust systems?
3. opinions on head studs?
4. Tuners or programmers?
5. Which gauges?
6. any other upgrades recommended?
I use the truck for alot of hauling as well as a daily driver and work truck. It is kind of a go everywhere and do everything vehicle. I know there is alot of information out there about what to do to these truck, and i have read a bunch of it, but some of it is contradicting so I would love to know what is working well for everyone else.
Thanks
Old Nov 14, 2011 | 06:19 PM
2006powerstroke90's Avatar
2006powerstroke90
Congrats on the new rig!
Get a scan gauge II monitor your temps
Ect vs eot and ficm voltage
You never really want to see a 15deg delta in the temps unless pulling on a long up hill. Ficm never really wants to go under 45v
Do all your maint on time and properly and enjoy your good reliable truck
Old Nov 14, 2011 | 10:01 PM
BLADE35's Avatar
BLADE35
I will add to stick with motocraft oil/fuel filters each one has certain requirmwents if you run motocraft you wont have to worrey about it and the truck will run right
You could end up with Majoir Problems if you dont run Motocraft Filters
Also might want to install the Blue fuel pressure spring upgrade for injector Health
And every so often after its up to operating temp drive it like you stole it that will help keep the turbo operating properly I usually do it going up a hill to give the turbo veins a good cycling maybe 1 time a week
for Exhaust go 4inch out the turbo back for optimal sound and preformnce
then go to this thread and post your email dont read all the posts just post email for the spread sheets Mark has done a Awesome Job collecting info on the 6.0
And Welcome to the 6.0 Forum
https://www.ford-trucks.com/forums/7...ew-owners.html
Old Nov 15, 2011 | 04:39 PM
mstiles19's Avatar
mstiles19
thanks so much i am going to have to look into the blue pressure spring, never heard of it.
Old Nov 15, 2011 | 06:10 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
As Benny posted above. you will have all the links and part#'s for the "blue spring" and most everything else that comes up in the spread sheets.
It will be one of the most used tools in your tool box.
Old Nov 15, 2011 | 06:29 PM
BLADE35's Avatar
BLADE35
Heres a good write up on the blue spring
Good BLUE spring with pics
Fuel Regulator Upgrade w/ Pictures - Diesel Forum - TheDieselStop.com
Old Nov 16, 2011 | 09:27 AM
mstiles19's Avatar
mstiles19
ok thanks, I took my truck to a local diesel shop to have them look over it. The only concerns they had with it were that the batteries were the original batteries (although they were still good), steering stabilizer was worn and there was an oil leak from the right side valve cover. Other then that they said it was good to go.
Any one else have the valve cover leak or hear about them leaking?
the truck has a 3,000 mile full coverage warranty on it but i don't think they will cover the batteries because they are still good, but i am going to see what they say about the oil leak and stabilizer.
Old Nov 16, 2011 | 09:29 AM
mstiles19's Avatar
mstiles19
Blade35 thanks for that write up. I am going to add that to my list.
Old Nov 16, 2011 | 12:50 PM
IABill's Avatar
IABill
Talking
M. Just dont ask about a SMOKE SWITCH or ask a question in someone elses post that might be slightly off topic. The PC police are here in force and will be on you like Oprah on a canned ham!!!
Old Nov 16, 2011 | 03:28 PM
Misky6.0's Avatar
Misky6.0
Matt, welcome to the 6.0 addiction club.!
I'll 2nd the scanguageII for monitoring vital temps/voltages/readings.
update your signature, it still lists your 5.4, and you'll get a bunch of
flak about an edge on the 6.0 (and the airaid also)
Also consider Optilube XPD (via internet) or DieselKleen (from autozone)
to improve the diesel fuel. I've just switched to Optilube and I prefer
it's dispensor/bottles over the DieselKleen.
Most importantly, enjoy the mighty 6 oohhh.
Old Nov 16, 2011 | 08:02 PM
mstiles19's Avatar
mstiles19
Thanks, I updated it. I will definatly miss my 5.4 that thing was a tank and took major abuse, everyone with diesel that I know could not believe I did the things I did with it and it was on an 8 cylinder gasser
I have been using DieselKleen but I also run it with B5, so is the additive still necessary? Seems o me like one of the things on the list of additives I have seen floating around says biodiesel is great.
Also any idea about the valve cover leak?
Old Nov 16, 2011 | 08:06 PM
mstiles19's Avatar
mstiles19
thats funny some of the kids around town have diesels they bought and i think the only reason they bought them was to as they call it roll coal, I am pretty sure they all have smoke switches....haha
Old Nov 16, 2011 | 08:14 PM
Snuggyworm's Avatar
Snuggyworm
welcome to the fte forum. congrats on ur ford. i hope u enjoy her as much as i enjoy mine.
Old Nov 16, 2011 | 08:16 PM
mstiles19's Avatar
mstiles19
haha i have been on here since 2007, just got a newer truck as my other had over 200,000 on the clock
Knucks
Mar 22, 2017 02:14 PM
swamp donk
Sep 30, 2010 02:26 PM
stephen.osborne1
Jan 9, 2010 09:23 AM
Flux
Aug 7, 2006 08:28 PM
