Fuel Filter change
Old Nov 14, 2011 | 03:29 PM
bdb2047's Avatar
bdb2047
Fuel Filter change
Changed filters today after looking at video and e-mails did not know about check valve as I drained about 1 gal out before reading all.A quetion I have ,when I tightened housing on DFCM it says to tighten till it stops.when i did this it stopped about 1/8 trun past where it was wires would not reach,I backed it till wires reached primed and started truck all seams OK. did take back apart before priming all looked good.Do I have a problem?About 15K on truck filters looked good no evidence of contamination
Old Nov 14, 2011 | 10:20 PM
Painted Horse's Avatar
Painted Horse
Tighten until you hit the positive stop. If that happens to place your wires in a bad place, I would unthread and rotate and see if you can catch a different thread so you end up hitting the positive stop.
Old Nov 14, 2011 | 11:02 PM
kper05's Avatar
kper05
Run through the prime procedures again to be on the safe side once you follow what PH said.
PH, is the new o-ring OK after an unthread?
Old Nov 15, 2011 | 04:38 PM
bdb2047's Avatar
bdb2047
I did take it off and tried to get it to engage threads at different location.Tried that twice also to check to see if I broke something.Just don't understand if positive stop why connections would not line up.Was only off maybe a 16th of a turn.Is runnig now and does not seam to a problem.Thanks
Old Nov 15, 2011 | 08:02 PM
Tom's Avatar
Tom
If it's running fine you're not sucking air. You shouldn't have a problem .
Old Nov 15, 2011 | 09:30 PM
cford716's Avatar
cford716
What check valve? I have watched the video and read the manual but didn't notice anything about a check valve. Am I missing something?
Old Nov 16, 2011 | 05:49 AM
bdb2047's Avatar
bdb2047
I did not know about check valve either.When I first drained filter it would not stop draining.Went back and read responses to video.One of them says there can be a problem when tank is over 1/2 full but if you loosen canister 3 turns a check valve will stop fuel flow.Worked for me.I also primed and started truck after each fiter was changed.
tracyclifton
6.7L Power Stroke Diesel
21
Mar 30, 2016 04:45 PM
Joe28443
13
Jan 10, 2010 06:55 PM
Powermoon
Mar 27, 2007 02:03 PM
Robert porovich
Jan 17, 2007 05:30 PM
MemOrex
Nov 10, 2005 12:05 AM
