Help Identify this Carb and quick question...
Old Nov 14, 2011 | 01:05 PM
EL_Musico's Avatar
EL_Musico
Below are a few pics of My carburetor. It's on a 360. Can you tell me what it is? I'm trying to find the model number but am not sure exactly where to look. I think it's a Holley 1848 based on pictures I've seen online, but I can't be sure.
I'm getting a little pool of gas on the manifold. In the close up photo of the carburetor, on the lower right corner, just below the screw, you'll see shiney gas on top of the black gasket. With the engine off, I wipe that off and it'll seep there again. Perhaps that's the leak. Can you guys confirm?
THe truck runs well when warm. When cold, it tends to hesitate when I accelerate under load. If the truck is parked the engine revs fine. When I put it in drive it hesitates and I have to feather the pedal to keep it on. THe accelerator pump seems to work fine, I get a good stream of gas as soon as I move the throttle.
Any way, here are my questions:
1. Is this the best carb for this engine?
2. Is that leak causing the hesitations under load when cold?
3. Is that leak easy to fix?
4. What model is this carb?
Old Nov 15, 2011 | 10:01 AM
MIKES 68 F100's Avatar
MIKES 68 F100
carb # is stamped on the choke housing front right facing carb . looks like 600cfm google that #
i think your leak is form the accelerator pump (pic 3) i see wetness there . i think you can buy just the accelerator pump . if not just get a rebuild kit
Old Nov 15, 2011 | 12:34 PM
GLR's Avatar
GLR
Ditto what Mikes said. Pump is avail separately. Make sure the cover is flat by rubbing it across some sandpaper on a flat surface, 220 grit works ok
Old Nov 15, 2011 | 01:14 PM
MIKES 68 F100
looks like you have an open port on left side of carb bowl ( the big one next to vacuum advance hose
Old Nov 15, 2011 | 04:48 PM
EL_Musico's Avatar
EL_Musico
THanks guys. What do I do with that open port? Is there supposed to be a vacuum hose attached there?
As for the carb number, is that the tiny little etching barely visible in the pic? Is that the model number? I'll take a look tonight, when I get home.
Old Nov 15, 2011 | 04:59 PM
MIKES 68 F100
I'VE never seen a port there before , i'd just cap it for now , maybe someone else knows what it is .
Old Nov 15, 2011 | 05:09 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Looks like a float bowl vent. Don't cap it, as that can lead to flooding issues.
Old Nov 15, 2011 | 05:27 PM
GLR's Avatar
GLR
Vent as Rogue says. I've seen them capped and hooked to air filter. Is there one in the rear ? Those two tubes near the center of the carb should lead to the floats as vents also.
Old Nov 15, 2011 | 05:33 PM
thechief66's Avatar
thechief66
Actually, you SHOULD cap it. That will prevent any dirt or debris entering the carb through that open port. The bowl will still vent through the vent in the airhorn.
BTW, what you have there looks like a standard Holley 600 CFM with electric choke (maybe a 9834 or 80457) but the front bowl is off something else. It should work fine for your truck if everything is set up properly.
Old Nov 16, 2011 | 12:29 AM
EL_Musico's Avatar
EL_Musico
Thanks, Doug. And everyone else who chimed in. I don't know all the parts of the carburetor, so I don't know what the bowl is. I took it into a mechanic today to have it looked at and possibly repaired. He mentioned he couldn't get a hold of a carburetor guy since not too many people deal with them these days. I'm gonna call someone else tomorrow.
Old Nov 16, 2011 | 12:20 PM
thechief66's Avatar
thechief66
The fuel bowl is simply the front part of the carb that holds the fuel (there's one on the back, too, on this 4 barrel carb) It's the part with the big "HOLLEY" stamped on it.
Holleys are pretty simple to work on, and there's lots of info about them online. You should try to rebuild it yourself.
Old Nov 16, 2011 | 04:46 PM
EL_Musico's Avatar
EL_Musico
Thanks again, Doug. I might go ahead and do that, especially with your encouragement. It's still at the shop. The truck has a charging system malfunction and they can't figure it out. I'm starting to think they have no idea how to deal with 45 y/o technology.
Old Nov 16, 2011 | 05:00 PM
GLR's Avatar
GLR
If you do decide to re-build the carb yourself.(the accelerator pump is real easy) , drain the gas out of the float bowls 1st. Clear a spot on the kitchen table (good luck) or good work surface. I like to use an old towel as it sort of keeps parts from rolling around. Just take your time and lay the parts out in order of removal, follow instructions in the kit. You might want to just replace the pump and see how it runs.
Old Nov 16, 2011 | 09:52 PM
EL_Musico's Avatar
EL_Musico
Looks like it's a Holley 80453. It's marked on the choke housing as you guys mentioned. I'm ordering an accelerator pump tomorrow morning and will try to replace it myself. I'll take pics.
Old Nov 17, 2011 | 08:02 AM
GLR's Avatar
GLR
Don't forget the base gasket if you take the carb off the manifold, you don't have to take the float bowl off but, if you do - float bowl gasket.
