truck died
Old Nov 14, 2011 | 12:43 PM
mdollar's Avatar
mdollar
truck died
My 05 6.0 f250 dieid while driving down the road. It was like someeone reached over and shut my truck off. Anyone have any idea qhat might do this?
Old Nov 14, 2011 | 05:29 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Nov 14, 2011 | 05:34 PM
Snuggyworm's Avatar
Snuggyworm
any symptoms? white smoke? rough idle?
Old Nov 14, 2011 | 06:01 PM
2006powerstroke90's Avatar
2006powerstroke90
When ipr failed it did the same exact thing.
Pull it and inspect it, under the turbo.
Old Nov 14, 2011 | 06:57 PM
BobbyB's Avatar
BobbyB
Have you checked for any codes?
You could check for fuel delivery. Remove the fuel filter cap, turn on the key and see if the bowl fills.
Unplug the ICP on the right valve cover and see if it starts. Also, check the FICM fuse and perform the FICM voltage tests.
Look at Bismics no-start procedure in the tech folder.
fordguy281
Oct 30, 2014 09:48 AM
dwood3311
Nov 18, 2011 10:36 AM
bwcjac
Aug 25, 2011 07:43 AM
newfordguy1
Mar 20, 2011 09:47 PM
2005F250
Feb 27, 2005 10:24 PM
