Whats the difference
Old Nov 14, 2011 | 12:06 PM
95f2504x4's Avatar
95f2504x4
And I've had ones come in that say heavy duty on the doors and they come up as the hd
Old Nov 14, 2011 | 12:11 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
oops the GVWR difference point is over or under 8500 lbs my bad when i said 8600.danr1's comment reminded me of this...but wasn't 8800 the max? (that's getting kind tedious anyway.)
so if your trucks door jam sticker reads 8500 or more, then you have the f250HD/F350 platform.
D50 front (instead of the D60 front of the F350) w/shorter rear spring blocks (which doesn't effect load rating,just height difference to match the front axle in 4wd models) was the only difference between the F250HD and f350's.
all f350's did come with 1 aux spring unlike the F250HD's too,though one could be ordered with it,or easily added as well.
frame,axles,brake system etc.etc. all the same.
the difference between a 2wd f250HD and the 2wd F350 trucks.....nothing that i know of lol.
with a GVWR of 8600 lbs,there is no question or doubt about it,you have a F250HD.
Originally Posted by tbirdscott
Are you sure you have the 50 in front? Since it isnt an extended cab it should have the hd44 instead.
Sounds like a standard f250 to me.
Scott
Scott,your not wrong.however this was in earlier years.
Originally Posted by 95f2504x4
It's right on the bottom of the axle that has the imprint designed into it that says d50 also the only reason I believe it's a ld is because when I scan it at work it comes up 95 ford f250 ld and we have the hd options in the computer but the vin reads and tells the cOmputers that it's a light duty
a computer is only as accurate as the info given it.
your computers database is inaccurate.
with a decent "truck eye" lol,you can look at a F250 LD truck and see it pretty clearly as a "f150 heavy half" if you will,type truck.
Old Nov 14, 2011 | 12:28 PM
95f2504x4's Avatar
95f2504x4
Ok thank you all for clearing that up for me I was wondering y I had to buy some hd parts if the trucks a ld but now I know it's not thanks
Old Nov 14, 2011 | 12:32 PM
danr1's Avatar
danr1
Yep any time you buy parts for it say "over 8500# gvwr", you'll get the correct parts if you do. The parts guy should ask you that but often do not (depending on where you go that is).
Old Nov 14, 2011 | 01:39 PM
95f2504x4's Avatar
95f2504x4
Right ya I pulled the rotors cause one was cracked and replaced them and the ones at the part store were incorrect idk if they just didn't ask but I went up to f350 brakes and they worked good
Old Nov 15, 2011 | 10:06 PM
95f2504x4's Avatar
95f2504x4
ok now see i called the dealer ship and they said the truck was a light duty off the vin also i have to call him back with my emmisions numbers or something. But he also said the 8600 gvwr was for the hd to....... And then he got confused lol, yes my truck confused the guy at the dealership.
abosely
Dec 3, 2015 09:16 PM
pidaster
Feb 11, 2012 07:14 PM
Jorp
18
Dec 22, 2010 06:54 PM
Gr8ride
Aug 4, 2003 06:04 PM
mjb1962
Mar 11, 2001 06:49 PM
