Have no idea what this could be but if I cruise for a few miles and come to a stop then mash on her good from a stop in creeper she will wind up good then start to studder clear out some smoke and then proceed to haul ***..it will sometimes do this in other gears but not always an does it engine warm or cold..the smoke is always a whiteish tint
lol... creeper is the thing you roll around on under your truck. Granny gear, granny low, low gear, etc is first gear. I have never heard first referred to as "creeper" either.
What you and I choose to call first gear is of no importance and obvisely I know what a creeper is ..so on to the important **** ..no black smok hrdly ever just a super healthy cloud of white and you might say it had a blue tint..but that is not for certain
I hope YOU aren't serious. Being a donkey to the people offering to help you seems a bit moronic. I guarantee you've missed out on good answers just because of how you've talked to these guys. Good luck...
Ooo I'm sure they can be men and take it on the chin like champs besides bad 12 has responded to plenty of my posts before so if he's butt hurt hewill chime in..ooops almost forgot this was starting to get like one of the sooper dooty forums
x3 ^^^^ what the hell is up with you guys comeing on here and ask for helpand act and make an *** out of your self!!!a little respect will go along way!!!!!good luck with granny low!!! creeper!
Well it appears an apology is in order then so I do apologize..it appears that the term I use to describe 1st gear is something that seems to be my general location as everybody I know also calls it creeper gear..hence the term creeping..soooo everything aside I do apologize to all offeneded I didn't realizie this was a local term
hmmmmm isn't white smoke = coolant? do you know what the smoke smells like?
Im sure someone else will chime in here w/more info.
Are all of your fluid levels staying in the normal range? coolant/oil?
Any bubbling in the coolant cap while running?
Also are you chipped, tuned or have larger injectors?
No chip yet and no tune stock injectors..I thought the same about coolant but the rads always full and the overflow stays where I filled it no coolant bubbles..I can catch a wiff of the smell ill have my buddy switch me cars tomorrow at work and ill try to get a taste lol
