speedo quit working
Old Nov 13, 2011 | 04:32 PM
NE14SAND's Avatar
NE14SAND
speedo quit working
shes a 01, 7.3, 4x4, crew. long. speedo quit and nothing else seems to be wrong, put in new vss and found 2 dead fuses. there is nothing visually wrong that i can find. i searched and everybody has other things wrong, not me. we did just have our first light rain and windshield does leak a bit (saw this in an other thread) so whats my next step???? thank you for you time.
Old Nov 14, 2011 | 07:19 PM
NE14SAND's Avatar
NE14SAND
so where and how do i start to track this down? not a clue what is the next step. thanks
Old Nov 14, 2011 | 07:24 PM
BigAlsPSD's Avatar
BigAlsPSD
I would start by checking to see if the PCM is putting out a MPH signal with a diagnostic tool, if it was, it could be the speedo motor or the cluster.
Old Nov 14, 2011 | 10:20 PM
sand_fiend's Avatar
sand_fiend
If your pcm is putting out a signal to the cluster and the cluster is not working, its a good bet that some moisture got to it if you have a windshield leak like you have said..
You could buy a used cluster at a junk yard if it turns out to be bad or have it fixed..
Here is a site that fix's clusters.. Ford / Lincoln / Mercury
take it out and clean all the pins on the plug and clean the connection side of the cluster. Maybe it got damp and has built up calcium between the connections ??
Old Nov 14, 2011 | 10:27 PM
Bonanza35's Avatar
Bonanza35
Usually when your VSS goes out your cruse controll stops working also. So if you changed it out, I guess your CC still works. Got to then be electrical I would think.
Chet
Old Nov 17, 2011 | 05:31 PM
NE14SAND's Avatar
NE14SAND
thank you i will try a test or 2 this weekend
jamien2
19
Jul 21, 2017 02:19 PM
'94IDITurbo7.3
22
Dec 9, 2012 11:17 AM
Josh2021
Feb 21, 2010 08:01 PM
97 HD
Nov 12, 2007 05:11 PM
ChristopherBarnette
Feb 3, 2007 04:17 PM
