Emergency!!!!!!!
Old Apr 12, 2003 | 04:21 PM
bronco351's Avatar
bronco351
Emergency!!!!!!!
Hi, I have a 1990 Ford Bronco. It has the 8.8 rear end. I began to change the Gear oil in my rear Diff. today. The problem I have is I completely strippen the fill plug. I can't put the fluid back in. Is there some other way to fill the diff back up?? This is my only TRUCK!!!!
Old Apr 12, 2003 | 09:18 PM
MustangGT221's Avatar
MustangGT221
Emergency!!!!!!!
You'd have to unbolt the rear end and turn it down, and pour the oil in with the cover off.
Old Apr 13, 2003 | 08:29 AM
John Barleycorn's Avatar
John Barleycorn
Emergency!!!!!!!
Man, that sucks.
I would take the pan off and add a drain / fill plug. I don't know how thick the pan is. It probably needs a bung welded to it.
Old Apr 13, 2003 | 06:38 PM
bronco351's Avatar
bronco351
Emergency!!!!!!!
Thanks anyway guys, I got it fixed with help from the Bronco forum. I filled it through the speed sensor!!!!
Old Apr 13, 2003 | 07:21 PM
EPNCSU2006's Avatar
EPNCSU2006
Emergency!!!!!!!
I'm glad you got it fixed, but I have to ask, how did you strip the fill plug?
Old Apr 13, 2003 | 07:30 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Emergency!!!!!!!
bronco351, they make an EZ-out just for the square 3/8" fill plugs. I worked at a lube shop years ago and saw many, many of these plugs stripped. I think I only ran across one severely rounded plug we couldn't get out for the customer. The tool works well.
A good tool store should have one.
Old Apr 13, 2003 | 07:41 PM
bronco351's Avatar
bronco351
Emergency!!!!!!!
Well, I broke it because, the darn bolt was so stuck on!! I cracked three extensions trying to get the bolt off!!!!
Old Apr 14, 2003 | 09:44 AM
Freight Train's Avatar
Freight Train
Emergency!!!!!!!
My fill plug stripped out a few years ago. Got it out after applying heat to the casting around it, and replaced it with a brass hex head plug with teflon tape on it. No leaks, and no seizing after that.
