LOW oil pressure at startup, and low RPM miss
Old 11-13-2011, 12:03 PM
FirecrackerKTM's Avatar
FirecrackerKTM
FirecrackerKTM is offline
1995 F150 4.9L 170K
1. In the mornings, my new to me truck is a little clattery at startup, only for the first two seconds maybe. Is this something to be overly concerned about? Previous owner took reasonably good care of it, and it fades away a little bit after a fresh oil change but is back before it's time for another. I don't like the way it sounds, but it is only for a couple of seconds and then it sounds fine. I do have a tiny tick when it's cold, from a lifter I imagine. I was thinking about replacing the oil pump.
2. Under 2,000, I have an occasional, arrhythmic miss. It's not bad, it doesn't get in the way, but it is a little annoying. It feels like hitting a small bump. CEL is not on, but I haven't plugged in a code reader yet.
Old 11-13-2011, 01:40 PM
rikard's Avatar
rikard
rikard is offline
Change the oil (10w 30) and use a Motorcraft oil filter. Do not use Fram. The 4.9 filters have a antidrain back valve so it won't clatter at startup.
regards
rikard
Old 11-13-2011, 04:29 PM
FirecrackerKTM
Hey for the same price it's worth a try. Do you think theres been much damage caused by the po not doing that?
Old 11-14-2011, 07:20 PM
FirecrackerKTM
What do y'all think about the hesitation?
Jolly Roger Joe
06-12-2018 07:58 AM
feo_nuts
1997 - 2003 F150
03-14-2013 08:33 AM
knivemaker
01-07-2013 05:48 AM
rick-73
49
04-15-2010 04:42 AM
capwater
1997 - 2003 F150
05-15-2008 07:54 PM
Quick Reply: LOW oil pressure at startup, and low RPM miss
