How To Replace Injector?
Old Nov 13, 2011 | 11:52 AM
MauleOne's Avatar
MauleOne
It looks like I have a bad injector on #1. (180K miles)
I have never replaced one of these before. Any hints?
I would like to replace them all but it is too expensive right now.
Thanks
Old Nov 13, 2011 | 11:55 AM
JamesHajek's Avatar
JamesHajek
Have you looked into rebuilding injectors? Like through Rosewood? Normally, when you start to see injector issues, the other injectors are not far behind..
Old Nov 13, 2011 | 12:30 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Follow this link, though I did not drain the head, I used plenty of shop towels and stuffed in the hole to soak up as much fuel/oil as possible.
https://www.ford-trucks.com/forums/4...-injector.html
Old Nov 14, 2011 | 12:43 PM
MauleOne's Avatar
MauleOne
I had to buy an injector from the local NAPA at a wildly inflated price. I won't even tell you how much because it is embaressing.
I did not drain the reservior or the head. Just pulled the old inector and the glow plug. Used rags to capture most of the oil and fuel befor installing new inector (rebuilt)
Cranked engine with glow plug out to clear cylinder.(Pulled #30 fuse)
Did buzz test to make sure inector worked.
Put it all back together. It started after several tries. Now it is too cold to want to go for drive to see if it fixed problem (minus 20F).
Understand it will take a while to clear air before engine will run normal if this has fixed it.
Will post results.
Old Nov 14, 2011 | 02:47 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Good to see, yes it will take 20-50 miles or so. It did mine, but it ain't no -20F here. Ouch!
Jerry Chaney
Jan 14, 2014 07:32 PM
F0rdF0rever
22
Sep 8, 2012 06:22 PM
WA.Ranger
22
Mar 15, 2009 09:27 AM
76Econoline
Nov 13, 2008 07:16 PM
BowDown
Mar 22, 2006 09:20 PM
