1978 - 1996 Big Bronco
Emergency!!!!!!!
Old Apr 12, 2003 | 04:09 PM
bronco351's Avatar
bronco351
Emergency!!!!!!!
Hi, I have a 1990 Ford Bronco. It has the 8.8 rear end. Today I began to change the gear oil in the rear end. The problem I'm having is I completely stripped the fill plug for the Diff. Is there another way to fill the diff. with fluid?? What do I do from here. I need an answer quick as this is my only truck! Thanks a Bunch guys!
Old Apr 12, 2003 | 04:11 PM
alanscott's Avatar
alanscott
Emergency!!!!!!!
When you say you stripped it, you mean the threads? or that you can't get the plug out.
Old Apr 12, 2003 | 04:12 PM
bronco351's Avatar
bronco351
Emergency!!!!!!!
I mean i can't get the plug out!!!!
Old Apr 12, 2003 | 05:15 PM
Big Red Bronco's Avatar
Big Red Bronco
Emergency!!!!!!!
Hi, is any of the plug above the differential?
If there is even a couple of threads, or even an 1/8 inch. You might be able to get something like a Vise-Grip on it. If so, get a propane torch, clean the plug area first. Heat the plug, then immediately put ice on it. The idea is to break the threads free by heating and cooling.
If none of the plug is showing, you will need to get a "easy out" square driver. Basically, it is a hardened steel square thing, that you will need to tap into the plug where you are rounded out.
then you back it out with a socket or wrench. they are found in most tool stores.
Now if you are talking about the plug in the differential cover, not the one on the axle, you can do the same thing. or just take the cover off and replace it.
Bruce(Big Red Bronco)
Old Apr 12, 2003 | 05:59 PM
dblue351's Avatar
dblue351
Emergency!!!!!!!
Just pull out the Speed senor on top of the pumpkin and fill it there. Just make sure you do not over fill it.
Old Apr 12, 2003 | 06:01 PM
alanscott's Avatar
alanscott
Emergency!!!!!!!
If you have access to a welder, can you weld something to it to use as a handle?
Old Apr 12, 2003 | 06:26 PM
Red_EB_Bronco's Avatar
Red_EB_Bronco
Emergency!!!!!!!
if all else fails you can always buy a new diff cover. I don't know how much money they are though. good luck man!
Old Apr 12, 2003 | 06:45 PM
dblue351's Avatar
dblue351
Emergency!!!!!!!
20 bucks will get you a pretty chrome one!
Old Apr 12, 2003 | 08:18 PM
bronco351's Avatar
bronco351
Emergency!!!!!!!
No, the problem is not the diff cover, it's the fill plug. I wanted to fill it through the speed sensor, but I can't figure out how to take it off!! Can you please explain to me how that comes out!!!
THANKS A BUNCH!!!!
Old Apr 12, 2003 | 09:41 PM
greystreak92's Avatar
greystreak92
Emergency!!!!!!!
The speed sensor slides straight out the top of the diff housing. You have to completely remove the one bolt that holds in down.
Old Apr 12, 2003 | 10:00 PM
bronco351's Avatar
bronco351
Emergency!!!!!!!
Ok, I did remove the bolt and I disconnected the wire. I pulled on the sensor pretty hard but it doesn't budge!! What am I doing wrong. Do you have to pry it off with a scredriver?? Please Help. Thanks a Bunch!
Old Apr 12, 2003 | 10:39 PM
greystreak92
Emergency!!!!!!!
thats news to me...mine I had to work at it a little bakc and forth to get it started but it eventually slipped right out.
Old Apr 12, 2003 | 11:27 PM
dblue351's Avatar
dblue351
Emergency!!!!!!!
Just put some pliers on it and wiggle it stright out. Should not be connected to anything else.
Old Apr 12, 2003 | 11:35 PM
bronco351's Avatar
bronco351
Emergency!!!!!!!
Ok, I'll try that tomarrow morning, I will let you guys know how it turns out. Thanks a bunch for your help!!
Old Apr 13, 2003 | 07:58 AM
Dazza's Avatar
Dazza
Emergency!!!!!!!
You could always just pull an axle out, lower it to drain the oil (or just crck the rer diff cover so the oil comes out) , then raise the axle tube and fill it with the correct amount of oil.
Thats the quickest way I do the 9inch (doesn't have a rear cover though, this would make it easier).
Daz.
