Intercooler install
Old Nov 17, 2011 | 09:56 PM
  #31
King7765's Avatar
King7765
I was originally going to use an E-99 spyder, but got frustrated trying to find one.
The shop is nice, it's my Dad's plumbing shop. But I took over a large portion of it... lol. He doesn't mind, he gets access to all my tools and equipment. I have a 94 ranger in the background. It's my off-road rock crawler. Here's my build thread on the ranger. Have fun reading through that bundle of fun!
Dana 60 SAS w/2.5 air shocks - Pirate4x4.Com Bulletin Board
Old Nov 17, 2011 | 11:02 PM
  #32
crash1's Avatar
crash1
Hello i my not of payed close enough attention but where are the 3" plenums from.
Old Nov 18, 2011 | 12:34 AM
  #33
strokin'_tatsch's Avatar
strokin'_tatsch
Those are stock Super Duty plenums. The bolt right on, but you have to weld up a couple holes in the SD plenums that the OBS plenums didn't have.
Old Nov 18, 2011 | 12:42 AM
  #34
strokin'_tatsch
Are you going to switch back to a stock 1.15 housing or keep the 1.0? The turbo is going to hate you with stage 2's and tuning, especially with the 1.0 housing. I know you can make it last with a 1.15, but not sure about the 1.0. Just thought I'd ask. Good work on the IC piping
Old Nov 18, 2011 | 06:05 AM
  #35
King7765's Avatar
King7765
The plenums are actually off an international 7.3 from the junkyard. It's origins are unknown to me. May have come out of a Super Duty or a school bus or something else. I JB welded Dimes on top of the extra holes. LOL. Ghetto fab'ed, but works good.
I'm going to stick with the 1.0 housing and try it. Jim at rosewood made a comment a month or so ago that some of his customers have his stage II's and the 1.0 housings and really like it. I don't rev my engine out to 3grand, so we'll see how it does.
Old Nov 18, 2011 | 08:32 AM
  #36
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
I liked the work in the IC piping, you are a master welding. Congrats. And what about the seal between turbo and flange? no leaks?
Old Nov 18, 2011 | 09:02 AM
  #37
bad12jr's Avatar
bad12jr
Travis what holes? I don't remember having any odd holes on my plenums when I switched.
Old Nov 18, 2011 | 09:25 AM
  #38
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
see the 7th pic in the post # 24 and you will see the holes.
Old Nov 18, 2011 | 05:54 PM
  #39
redman84's Avatar
redman84
Sorry to stray, but what is your radiator from?
Old Nov 18, 2011 | 06:41 PM
  #40
King7765's Avatar
King7765
I only took it for a short run down the street, engine was cold and I didn't push on the fun pedal at all.
The radiator is factory...... is yours different or something?
Old Nov 18, 2011 | 07:59 PM
  #41
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Yes that is from early models, ours are like this one.
Ill be waiting for the leak of the flange OK?
Old Nov 18, 2011 | 10:47 PM
  #42
bad12jr's Avatar
bad12jr
Sorry didn't remember those. I need to look at mine. .
Old Nov 19, 2011 | 02:30 PM
  #43
King7765's Avatar
King7765
Truck runs like a freaking rocket now.
That flange might be leaking. Really hard to tell. I did so much to this truck this week I don't know what normal is anymore.
1.0 housing
IC
stage II's
T-500
PHP chip
Those things will really change a truck. But I heard a swoooooshing sound from the front area. Could be that flange leaking.
What is a good way to test it? Wrap a thin plastic bag around it and see if it is torn when I romp on the throttle?
Old Nov 21, 2011 | 01:40 PM
  #44
strokin'_tatsch
1.0 housing
IC
stage II's
T-500
PHP chip
Build a "boost leak detector" out of PVC pipe, a cap and a valve stem. Attach that to the intake system and hit the system with compressed air. I usually regulate the air down to around 30-35psi. Spray the spots you want to check for leaks with soapy water, and watch for bubbles while your feeding it with air.
Old Nov 21, 2011 | 01:54 PM
  #45
King7765's Avatar
King7765
Will do.
Time to go to homo depot.
