New Member
Old Nov 15, 2011 | 11:58 PM
BigAlsPSD's Avatar
BigAlsPSD
Just got it, Good looking truck, here it it
Old Nov 16, 2011 | 12:04 AM
iland300's Avatar
iland300
Everything seems good and in good condition, but now I have to take care of my truck now. So, is it true it can pull upto 20000 lbs cargo in flat bed trailer like what the seller told me.
Old Nov 16, 2011 | 12:11 AM
BigAlsPSD's Avatar
BigAlsPSD
Maximum Trailer/Hitch Limits - lbs (kg)
F-450/F-550
Max. Tongue Weight 600 (272)
Conventional - Weight distributing 16,000 (7,257)
Max. Tongue Weight 1,600 (726)
5th Wheel/Goose Neck 24,800
Old Nov 16, 2011 | 12:13 AM
BigAlsPSD's Avatar
BigAlsPSD
F-450/F-550 Super Duty, Manual Transmission,
Fifth-Wheel Towing:
F-450 6.8 V-10 14,700k,l
F-450 4WD 6.8 V-10 14,400k,l
F-450 7.3 TD 18,200k
F-450 4WD 7.3 TD 17,900k
F-550 7.3 TD 18,100k
F-550 4WD 7.3 TD 17,800k
F-450 Crew Cab 6.8 V-10 14,200k,l
F-450 Crew Cab 4WD 6.8 V-10 13,800k,l
F-450 Crew Cab 7.3 TD 17,600k
F-450 Crew Cab 4WD 7.3 TD 17,300k
F-550 Crew Cab 7.3 TD 17,500k
F-550 Crew Cab 4WD 7.3 TD 17,200k
F-450/F-550 Super Duty, Automatic Transmission,
Fifth-Wheel Towing:
F-450 6.8 V-10 16,700k
F-450 4WD 6.8 V-10 16,400k
F-450 6.8 V-10 18,700l
F-450 4WD 6.8 V-10 18,400l
F-550 4WD 6.8 V-10 16,600k
F-550 4WD 6.8 V-10 16,300k
F-550 6.8 V-10 18,600l
F-550 4WD 6.8 V-10 18,300l
F-450 Crew Cab 6.8 V-10 16,100k
F-450 Crew Cab 4WD 6.8 V-10 15,800k
F-550 Crew Cab 6.8 V-10 16,000k
F-550 Crew Cab 4WD 6.8 V-10 15,700k
F-450 Crew Cab 6.8 V-10 18,100l
F-450 Crew Cab 4WD 6.8 V-10 17,800l
F-550 Crew Cab 6.8 V-10 18,600l
F-550 Crew Cab 4WD 6.8 V-10 17,700l
F-550 Crew Cab 7.3 TD 17,600k
Pulled that information from here http://www.wilkinsrv.com/PDFs/00towingguide.pdf
Old Nov 16, 2011 | 12:28 AM
iland300's Avatar
iland300
F-550 Crew Cab 7.3 TD 17,600k, so it can pull more as I can see it can pull 17,600K which is 1K = 2.2 lb
Old Nov 16, 2011 | 12:41 AM
BigAlsPSD's Avatar
BigAlsPSD
No that is lbs the k is in the legend/footnotes requiring 4.88 axle, l requiring 5.38 gears.
Old Nov 16, 2011 | 06:26 PM
iland300's Avatar
iland300
Please, request you guys of not only use abbreviations, as some of us try to learn the ford and its defects, when you just put the abbreviation, we totaly loose the contents. Thanks
Old Nov 16, 2011 | 06:31 PM
BigAlsPSD's Avatar
BigAlsPSD
In my post I attached the link to the towing guide that I referenced the information from, on that link it showed what the abbreviations were for? I apologize.
Here are a list of common acronyms used in the forum
https://www.ford-trucks.com/forums/4...re-on-fte.html
Old Nov 16, 2011 | 08:26 PM
beanhead6D5's Avatar
beanhead6D5
Welcome to FTE! Thats a nice looking 550 for 300,000 on the ticker.
Old Nov 16, 2011 | 09:02 PM
iland300's Avatar
iland300
Thanks, I printed all the abbreviations, so will try to follow with your coments and it will help a lot of guys like me to get to know the ford better. Out of corusity when I was in Iraq, the iraqi police were using a lot of Ford pick ups in their patrol, can realy ford withstand the desert heat tempreture for a long time to come.
Old Nov 16, 2011 | 09:05 PM
BigAlsPSD's Avatar
BigAlsPSD
The cooling systems for these trucks is a very good system if everything is working as it should be.
Old Nov 17, 2011 | 06:46 PM
iland300's Avatar
iland300
I printed all the link abbreviations, but, reading some of the posts to catch up with you guys are some not here, the abbreviations are php, gp, uvch, psd, gpr, hpop, icp, idm. Thanks.
Old Nov 17, 2011 | 07:12 PM
  #28
BigAlsPSD's Avatar
BigAlsPSD
Originally Posted by iland300
I printed all the link abbreviations, but, reading some of the posts to catch up with you guys are some not here, the abbreviations are php(Power Hungry Performance), gp(Glow Plug), uvch(Under Valve Cover Harness), psd(PowerStroke Diesel), gpr(Glow Plug Relay), hpop(High Pressure Oil Pump), icp(Injector Control Pressure sensor), idm(Injector Drive Module). Thanks.
You're welcome, see the responses in Red
Old Nov 18, 2011 | 12:30 AM
  #29
iland300's Avatar
iland300
I am using this truck for transportation in the mid west, so it is goin to be my income now after the militry. I will start working next week on monday, so I checked everything now and all is good. I check the radiator, engine oil and the transmition gauges every day even I have picnic mat that allows me to check the bottom for any leak while it is heating, so what else you think I should do while reading here and follow up with you guys to keep this truck stable for my work.
Old Nov 18, 2011 | 01:24 AM
  #30
BigAlsPSD's Avatar
BigAlsPSD
There are a couple of great threads for things to check or change for preventive maintenance or prevention of a failure down the road.
https://www.ford-trucks.com/forums/5...questions.html
https://www.ford-trucks.com/forums/1...on-thread.html
Here a another of good things to look through as well.
Welcome to guzzle's Ford PSD Web Pages
