Transmission problems!
Old Nov 11, 2011 | 01:23 PM
Chris Guthro's Avatar
Chris Guthro
Hey guys. My 93 F150 4.9 M5OD is having some issues. When I go to put it in gear it grinds, and wont go in. I check the fluid in it and there is fluid. Even on the highway if i do get it to go it comes out the odd time when i let off the gas. Can anyone tell me what it is?
Old Nov 11, 2011 | 01:32 PM
Lazy K's Avatar
Lazy K
Sounds like the clutch is not fully disengaging. First thing to do is check the fluid level in the master cylinder resevoir. If low top it up with Dot3 brake fluid, pump the pedal and check for any signs of a fluid leak.
Old Nov 11, 2011 | 02:23 PM
White 97 xlt's Avatar
White 97 xlt
^^^^X2^^^^
Old Nov 11, 2011 | 04:38 PM
Chris Guthro
There is fluid in it, and when i pull over and put some in it and pump the pedal it goes away for a tiny bit then it starts all over. would my clutch be going?
Old Nov 12, 2011 | 08:22 AM
Chris Guthro
anyone else have any idea what could causing this? would it be because my clutch is gone?
Old Nov 12, 2011 | 09:35 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If the clutch was worn out you would have the opposite problem.
It would not be driving the transmission.
You would smell the friction material burning.
If it pops out of gear on trailing throttle and has a problem going into gear I would think the syncro's in the gearbox are bad.
Either that or the shift forks are worn or bent.
Dragging and not getting it fully into gear.
Old Nov 12, 2011 | 11:14 AM
Chris Guthro
So im almost better off getting another tranny. I figured it was the tranny itself. But is it common for everygear synchro to go bad? seems like a big job to replace the synchros
Old Nov 12, 2011 | 12:05 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You could still have a clutch release problem.
I just don't see that causing it to pop out of gear once you do get it in.
Is this something that's been getting worse, or did it happen all of the sudden?
Old Nov 12, 2011 | 12:17 PM
Jigger2020's Avatar
Jigger2020
Sometimes the firewall moves (flexes) & does not allow the clutch to disengage, that could be the grinding part
Usually not all the syncros wear out at the same time
Old Nov 12, 2011 | 03:35 PM
Chris Guthro
its hasnt really happened til the other day but now its getting worse. What could cause the clutch to not dissengage? but at first it was only happening to 3rd gear, then now its every gear.
Old Nov 12, 2011 | 06:14 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There area lot of clutch issues with these trucks.
First and foremost is the little plastic clip that holds the clutch pedal belcrank to the master cylinder pushrod.
Cheap and easy repair. (if the pin isn't worn)
You can get the retainer clip in the Dorman HELP! section of your local autoparts store.
Second is the firewall flexing and tearing around where the master cylinder mounts.
There are reinforcement kits for this.
Third would be the bushings in the pedal support. (cast aluminum piece, up under the dash) wearing out.
And even the holes in the metal support itself becoming oval.
Then,of course there's the obvious... failing master or slave cylinders.
Old Nov 12, 2011 | 08:50 PM
Jigger2020's Avatar
Jigger2020
Jim thats a great write up, its gotta be one of the above............I forgot about that little plastic bushing, that could be it......
Old Nov 13, 2011 | 05:23 PM
Chris Guthro
Thanks Guys! the slave cylinder was replaced before i got it. which wasnt long ago, How do i know where the pushrod is? and know if its worn?
Old Nov 13, 2011 | 05:31 PM
Jigger2020's Avatar
Jigger2020
Chris, go back & read post # 11
Old Nov 13, 2011 | 06:55 PM
Midnite1987's Avatar
Midnite1987
look up under the dash and move the clutch pedal and follow the linkage. theres the rod that goes throught the firewall. well where the rod connects to the linkage inside the truck there is a plastic bushing. i had to replace the little lever on the end ad the pin was worn out.
