Some progress!!
Old Nov 14, 2011 | 12:48 AM
badger_hound's Avatar
badger_hound
Nice work Dan. Hope you get it running by Thanksgiving.
Old Nov 14, 2011 | 10:44 AM
old_dan's Avatar
old_dan
Originally Posted by barnfind 51
Looks Great I like the way he ran the tail pipes. I see you are using shorty headers. How is your steering with the IFS,I saw your pic of the steering set up. It is off set to miss the headers. I have a jag IFS and was wondering about the shorty headers and if they will work.I am not that far along to fab some up but was interested in your set up. Any way your truck is really coming along. Great Job!!
I used 3 Univ joints and a heim bearing to miss the exhaust. I basically set the engine in place with the headers to center it up so that each exhaust outlet would have a straight shot between the frame members. This shot is a mock-up with the heim bearing mount tack welded in. I did get some binding in the steering, but it turned out that one of the DD rods was stuck too far into the univ joint & was hitting inside. I did shorten the one rod and extended the heim bearing out a little to reduce the angle....so, no binding now!!
Old Nov 14, 2011 | 10:46 AM
old_dan's Avatar
old_dan
Originally Posted by Jeff and Nicolle
How long have you been working on the truck? It seems to me that you haven't had it that long! But I can only base that on when you became a member here, which doesn't mean squat, I know.
I've had the truck for 12 years...but it sat behind the barn until right around the holidays in 2009....so really I've been working on it for 2 years now!!
Old Nov 14, 2011 | 10:54 AM
old_dan's Avatar
old_dan
I looked at your time warp album, never saw that one. Very nice! What color green is that? I like it! I thought Meadow Green but it looks darker?
The green is Rock Moss Green....I bought it from TCI in San Diego. They sell on ebay and are really good about shipping and customer service. That paint is a single stage & it sprays well....that is until the HVLP decides to start acting up. For the next go-around, I'll probably pull out the old high pressure spray gun. I used to do dope and fabric work & have painted several fabric airplanes with my HVLP, so I was really disappointed when it started acting up....It wouldn't have happened with some dope or laquer that I could have simply poured back into the can....nooo...it happens when the hardener is already added to the paint. It's not a big deal...I have to sand down the bed and shoot a light coat over the existing orange peeled paint.
Old Nov 14, 2011 | 12:42 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
I use to have an HVLP gun and I loaned it to a "FRIEND". never got it back, he says he gave it to me, but I know better. Needless to say, that won't happen again...Nice work though!
my steering linkage issues looked very similar with the JAG IFS, so I guess it's the 351W that creates the steering issue. I am at work and don't have pics here, but later I will post what mine ended up like. You have all those expensive joints, mine are salvage yard, but they do the job. Just not as pretty!
Old Nov 14, 2011 | 09:26 PM
Jeff and Nicolle
Just a picture of my steering joint setup to compare to from one 351W to another. I thought I had a final product but it's not any different except for the wood is now steel.
Old Nov 14, 2011 | 09:35 PM
Jeff and Nicolle
Here is my first setup, that looks alot like yours in terms of three joints, but I had some binding. may have been due to the factory joints i am using.
Old Nov 15, 2011 | 02:58 AM
barnfind 51's Avatar
barnfind 51
Hey Jeff are those the Shorty Headers? If so would a inch offset with the motor be helpful? just a thought. I have a book on building a small block on a budget,I know you big dogs with the 351's don't worry about the the dollars!! LOL in the book it has some exhaust manifold that dump out the back the only thing is they are almost 400 beans which is to rich for my blood. Anyway thanks for the pic's guys it sure helps to have the info to build these trucks.
Old Nov 15, 2011 | 03:00 AM
barnfind 51
Jeff great looking shock mounts. There you go another problem solved. This is sure a great site!!
Old Nov 15, 2011 | 07:19 AM
Jeff and Nicolle
Hey there George! Yes the headers are shorty's for the 5.0 Mustang 86-93
and offsetting an inch to the passenger side will render frame to header clearance issues. Maybe some of those block huggers would help, but they would have to dump in the rear on the driver's side.
I will type more but at work, gotta go!
wc870
Jun 21, 2016 09:59 AM
jordymike
Dec 31, 2014 02:47 PM
1952henry
Apr 2, 2012 04:57 PM
davewave649
22
Dec 17, 2011 12:45 AM
vinmanin
Feb 22, 2011 11:36 AM
