Threw a Code
Old Nov 11, 2011 | 11:45 AM
Lonewolftx's Avatar
Lonewolftx
Question Threw a Code
Engine light came on this AM and through code P0460? Any insight to what this code means? Appreciate the help. Thanks.
Old Nov 11, 2011 | 11:56 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
P0460 Fuel Level Sensor "A" Circuit
Keep this PDF handy for future code questions:
http://www.dieseltalk.com/support/DTC.pdf
Not familiar with this code. Sorry.
Old Nov 11, 2011 | 12:02 PM
amdriven2liv
Saw a thread on this code once, someone had this and found a blown fuse. His was an 03 and it was fuse #45. Not sure if it would be the same on an 06.
Old Nov 11, 2011 | 04:03 PM
bpounds's Avatar
bpounds
I would definitely reset that code, and see if it comes back. Fuel level sender problems can be very intermittent. I get one once in a while, and so far it has always corrected itself after some sloshing. You can also reach up over the fuel tank and reseat the electrical connector, to eliminate possible bad connector issue.
Some guys have had luck running a tank of Techron cleaner. I wouldn't hope for much, but I guess it cannot hurt.
If it just won't fix itself, a new $400 pickup assembly is in your future.
Actually, the code will probably reset itself if it fixes itself.
Kevinm1980
Jan 8, 2019 12:16 PM
JoseFeli
Mar 4, 2011 09:52 PM
brainfart
1983 - 2012 Ranger & B-Series
Apr 12, 2006 08:37 PM
rmarion
Sep 19, 2004 07:51 PM
