well I'll have access to the 17* hpop from that motor as well. I could prob grab it. But is there a way to deal with the oil draining back from the SD hpop in the OBS trucks?
To use the 17* HPOP on a 95 you will have to change the front engine cover and oil pickup tube that means pulling the motor. Just sent your pump to Joey and have it built to a T500
ouch, so maybe just wait until I can just afford stage 1 or 2's? The only reason I was considering this is I have to get my TS reburned for my 5spd conversion anyways and I had access to them so I figured why not but I guess not lol
Darn fordpride, you beat me to it haha. But thanks for an actual number. Why if you send him yours its 350 but if you have one built and then you send in your core iys over a grand?
Also fordpride, while your here whats the point of the 203* tstat? Does it add engine performance to get the motor to a higher temp on these trucks? Or is it just so you have heat in the winter? haha
Just runs the coolant a little hotter before opening. I wouldn't call it a performance mod...
