Headers or Manifolds?
Old Nov 9, 2011 | 08:03 PM
Blue and White's Avatar
Blue and White
I am working on rolling upgrades to a '78 F250/400M with low miles. The short term list includes new exhaust to replace the tired OE style 2 1/2" into 2 1/4" system. I plan a dual kit, probably Hooker's. Next step upgrades inlcude some more breathing help in the form of a 4 bbl or FI and possibly a small cam.
I am debating headers. Headman offers a thermal coated header to fit the truck. Its a little spendy but looks like a nice piece.
Has anybody tried the Headman? Any comments welcome.
Old Nov 9, 2011 | 08:43 PM
wyckedcombo17's Avatar
wyckedcombo17
Is this a race truck? Frame off? If not, stick with your manifolds.
Yeah, they're more restrictive than headers, but they're tougher and give you more low end grunt. Just run true duals off the manifolds, you'll see an improvement for sure.
I'm going to be freshening up my 400 too. Cam, timing, intake, carb, dizzy, egr delete, valve job. Sticking with the manifolds myself
Old Nov 9, 2011 | 08:59 PM
Blue and White
Its a truck truck... not daily driven but will need to work hard and long from time to time including pull a heavy trailer. With 4.10 gears, it does spin pretty well though.
Old Nov 9, 2011 | 09:19 PM
'76F-100's Avatar
'76F-100
I like headers. I put headers, straight up timing gears, comp cam 270H, Edelbrock performer intake and carb on my 400. MONSTER! Coated is good too, you won't roast your starter lol.
Old Nov 9, 2011 | 09:37 PM
HIO Silver's Avatar
HIO Silver
Headers, a 2.5-inch exhaust tubing and free flowing mufflers is worth 15% to 20% across the board. A real set-of-the-pants difference in my experience (but with an FE).
If you don't already have an open element air cleaner and filter then that would be the first thing to do. It's amazing how restrictive stock air cleaners are. A good 10-15 hp gain typically... that's awesome bang for around $60.
L&L makes some really nice headers. JBG carries 'em.
EFI? F.A.S.T. XFI and Powerjection are at the top of my list.
Old Nov 9, 2011 | 09:43 PM
akforceten's Avatar
akforceten
I say manifolds, less exhaust leaks an more low end torque .
Old Nov 9, 2011 | 10:05 PM
7Ford6's Avatar
7Ford6
A cold ram air filter will provide more power than an open element air cleaner...
"The amount of horsepower an engine makes is directly related to the density of the air entering the engine.
The Ram Air Cleaner delivers higher density air by reducing the temperature and slightly increasing pressure at high speed.
For each 10° reduction in air temperature you can expect to increase horsepower by 1%.
Considering that under hood temperatures regularly reach 160° when the outside temperature is only 70°, the incoming air temperature may be reduced by up to 90° and gain 9% in horsepower.
On a 400 horsepower engine 9% is 36 horsepower! This cold-air intake made a 35 HP gain on a 466 HP Small Block Chevrolet!
The under hood temperature of the car was 118 degrees, with the SMW Cold Air Cleaner, the air temperature going into the carburetor was reduced to 68 degrees."
Quoted from - Schmidt Motor Works Ram Air Cleaner
Old Nov 9, 2011 | 10:13 PM
HIO Silver's Avatar
HIO Silver
I concur. Thanks for your contribution. I was only citing the restriction cause by the physical attributes of the stock air cleaner assembly- not the inlet air temperature.
Good info for the OP to consider.
Old Nov 9, 2011 | 10:23 PM
'76F-100's Avatar
'76F-100
I still say if you want headers, go for it. You can get narrow tube headers that maintain exhaust velocity and therefore your torque. And unless you are driving your truck around at 1200 RPM all the time (unlikely), you won't notice the small torque loss, but you will notice the horsepower gain.
Old Nov 10, 2011 | 03:39 AM
kelsey_kaye's Avatar
kelsey_kaye
I'd go for the headers, but make sure to wrap them up.
Old Nov 10, 2011 | 05:06 AM
Blue and White
Thanks for the comments. On the intake, the OE setup is cool air with a very small filter as you guys know. When I change it, I'll look for an aftermarket cool air setup with 14x3 filter.
If I do go EFI it will likley be Comp EZ EFI. I'm running XFI on another vehicle and like it. I'd like to keep this one simple though. EZ EFI, a rebuilt Duraspark distributor and MSD box sounds like it will work well.
Old Nov 10, 2011 | 05:18 AM
7Ford6's Avatar
7Ford6
The Poor Mans Fuel Injection.....
https://www.ford-trucks.com/forums/1...-a-300-i6.html
Old Nov 10, 2011 | 05:26 AM
stuck in the 70s's Avatar
stuck in the 70s
+1 on the manifolds
headers turn to crap unless your gonna get good stainless steel jobs that will blow the budget. then you have to think that these motors want a little back pressure. i do how ever notice a difference if my cold air intake is unhooked vs hooked up especially when towing a heavy load.
the only way i use non factory headers is if the motor is going over 400 in the torque or hp figures then they get stainless. my built 351w new edge stang even runs a set of factory 5.8 cobra headers and it has no issues whipping on some new vetts. i have a set of big tubes hanging on the wall but refuse to use them and loose back pressure and screw up my world heads.
Old Nov 10, 2011 | 05:52 AM
elgemcdlf's Avatar
elgemcdlf
I have always preferred manifolds. I have always had exhaust leaks with headers to the point my current truck has the collectors cut off and the pipes welded straight to the headers. Then of course are the mounting bolts that work loose. I am huggin 50. I just want to walk out, start it up & drive trouble free. I don't want to spend every waking moment constantly redoing what has been done due to design issues. If you are racing that is one thing. Street use any gain with headers over manifolds will never be noticed.
We plan on doing a mild build on a 460 getting 650hp with manifolds.
Old Nov 10, 2011 | 10:03 AM
BuiltFordTough302's Avatar
BuiltFordTough302
I went with the Hedman Elite Thermal Coated Long Tubes on my 78 F150 with a mild 400 and have been very happy with them. I think there was a noticible difference over the stock manifolds on my engine. The coating is very nice compared to the painted headers I had on my F100 and they fit nicely as well although starter changes may be a bit of a pain now. I think they are worth the money if you are going to be installing a cam and intake/4 barrel carb.
