Transfer case not fully engaged
Old Nov 9, 2011 | 01:57 PM
sfordgoat's Avatar
sfordgoat
Hello,
I recently put a bearing kit in the BW1356, manual shift, in the 89 f150.. on the bench it worked .. seemed to shift and lock the drive chain when in 4 hi and low..
Got it back into the truck and it appears that there is something not fully engaging, as I hear a engine RPM related "ticking" type of sound.. almost like the 2-4 wheel drive collar is not mated completely. It stuck in 4-low, but I did get it back into 2-hi after working with it.
As I re-assembled it I remember that it seemed like I needed to change the depth that the main shaft went into the end bearing, (which was changed), in order to make the collar engage. I also noticed that the main shaft bushing was lower in support hole.. in order to make it line up correctly. Anyone have an idea what may be causing this and if there is a measurement / spec associated with the distance the main shaft is set in the end bearing? and/or a spec on the bushing depth from the deck of the case?
It also looks like the planetary gear that is attached to the main shaft rides at a different height.. not exactly flush with the top of the gear that is locked in the case.
any ideas would be greatly appreciated..
Steve
Old Nov 10, 2011 | 10:54 AM
sfordgoat's Avatar
sfordgoat
Got it..
After working the shifter in and out and in and out and driving forward and backward and forward and backward a few times, locked the hubs and took a spin...
All sounds normal again...
Goatman
Old Nov 13, 2011 | 08:56 AM
LLADNAR's Avatar
LLADNAR
you may want to make sure all of you tires are the same diameter, sounds like you may have been binding,, considering that you had to go forward and back to make it work right.
Mattyhawk
Apr 25, 2016 08:40 AM
biederboat
Mar 18, 2010 08:31 AM
DDanimal
Bronco II
Sep 20, 2008 11:20 AM
powerplay
Aug 11, 2006 11:56 AM
somethingurnot
Feb 18, 2004 06:24 PM
