which auto tranny will fit?
Old 11-07-2011, 06:40 PM
CB06n70fs's Avatar
CB06n70fs
CB06n70fs is offline
hello everyone, pretty new to this so be gentle... i have a inline six (240) and it has a 3 speed trans that someone moved to the floor... which auto tranny will bolt right up without much hassle? also will i need to run lines or anything? any advice would help
Old 11-07-2011, 09:49 PM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
Any auto with the sb bell housing will fit. I would think the c4 or c6 would be the easiest, and the c6 being the strongest of the two. With those you only need a vacuum line and the neutral safety switch. Of course I would hit the j/y and get the right cross member, mount, and drive shaft too. Along with that you'll need a steering column for an auto, with the shifting arms.
Old 11-07-2011, 11:46 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
You will also need to add a trans cooler. Either one inside the radiator (most replacements already have it) or one that mounts in front of the rad. Without the cooler, the trans will burn up in a very short time.
richard eisnaugle
10-03-2017 03:23 PM
TNTRUCKS
01-24-2011 02:10 PM
td351w
02-06-2004 11:08 AM
82F100PU
10-07-2003 11:43 PM
GeneStoner
12-31-2002 09:16 PM
Quick Reply: which auto tranny will fit?
