1990 f150 oil pan leak
It is possible but it is a PITA.
Unbolt engine mounts
Jack up engine as far as it will go(plenum in to firewall)
Unbolt pan and drop as far as possible.
Remove old gasket and silicone.
RTV in the 4 corners.
Sneak in new gasket with out wrecking it(get the FORD one piece steel w embossed rubber gasket)
Put pan backup in place and torque bolts.
Lower engine
that is if the gasket is leaking and the pan is NOT rotten
Lower engine
gordo2
09-13-2013 12:20 PM
Orange84
04-03-2013 12:07 PM
mr.fordneck
04-17-2012 11:01 AM
