NEXT.....
Old Nov 7, 2011 | 10:23 AM
EXbowtieguy's Avatar
EXbowtieguy
NEXT.....
I'm doing my high idle mod and am not getting any juice from my Blue/white wire per a muli-meter ?
Any idea which fuse feeds that wire or where the other end is so I can do a continuity test ?
Thanks guys !
Old Nov 7, 2011 | 11:02 AM
raptor131's Avatar
raptor131
i haven't done this mod yet but i found this
SEIC or BCP Wire?
You can hook the switch to either of these wires to achieve high idle. However, they each have slightly different behaviors. If you're doing this mod to help keep the AC cold or the heater hot, or keep the revs up when jumpstarting somebody, then you probably want to use the BCP (Battery Charge Protect) wire. If you're doing this mod to use the PTO (Power Take-Off on your transmission), then you probably want to use the SEIC (Stationary Elevated Idle Control) wire.
If you want to hook up to the BCP wire, find the purple wire with the light green stripe in the bundle just near the top of the emergency brake pedal. Note: don't be fooled into using the light green wire with the purple stripe. That's the output wire for a BCP indicator lamp.
If you want to hook up to the PTO wire, find the solid orange wire in that same bundle (near the e-brake).
i don't know what wire you have, what year is yours /this is for the 05-06
Old Nov 7, 2011 | 11:21 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Thanks guys !
Fuse #29.
It's just under the schematics in the High Idle Mod link:
High Idle Mod
EXbowtieguy
Mines an 04.... Different color wires.
White w/ lt blue stripe behind the OBD2 is supposed to be hot when key is on ? Mines not hot KOEO or KOER ?
Old Nov 7, 2011 | 11:25 AM
EXbowtieguy
Originally Posted by amdriven2liv
Fuse #29.
High Idle Mod
Thanks man ! Guess I should slow down a bit and read the whole link next time! I'll check the fuse.
Old Nov 7, 2011 | 11:55 AM
amdriven2liv
Heck, I did this sometime ago. When you posted the question I went on a search for the answer and took me all over the place! Then I went to the high idle link to see if I was using the correct wording. Ding! Well, that was fun.
Are you doing a LED switch?
Old Nov 7, 2011 | 12:20 PM
EXbowtieguy
Nah.... I have a lighted toggle switch Layin around I'm gonna throw at it.
Old Nov 7, 2011 | 03:41 PM
EXbowtieguy
BINGO.... No fuse in slot 29 !
Thanks
Old Nov 25, 2011 | 11:06 AM
EXbowtieguy
Well I finally got a few minutes to wrap this mod up so i figured Id wrap up the thread for the next guy.... Not reinvinting the wheel here but figure maybe something I say or did may be that little bit that makes the light go off for someone else
I didnt use any butt-connectors just good old fashioned solder and heat shrink joints,some of the spots were a little tight with my torch but ive got a thin piece of thin aluminum i use in tight quarters so I dont burn mt dash up
Anyway heres the finished product.... WORKS GREAT
And BOOM no maore wetstacking
Old Nov 25, 2011 | 11:12 AM
amdriven2liv
What is the little 'LED" light above the switch for?
Old Nov 25, 2011 | 11:19 AM
zhilton's Avatar
zhilton
I didnt use any butt-connectors just good old fashioned solder and heat shrink joints...
Sounds like you did a real quality job; butt connectors end up being pains in the butt down the road.
Old Nov 25, 2011 | 11:21 AM
EXbowtieguy
After market alarm.... Blinks when "hot"
Old Nov 25, 2011 | 11:22 AM
amdriven2liv
Thanks, and thanks for coming back with information on the job you did.
F250SDPowerStroke
Jan 26, 2019 10:43 PM
mtnxtreme800
Jan 25, 2013 09:48 AM
DieselVol
Aug 25, 2012 03:21 PM
brianhea
Feb 9, 2007 02:48 PM
