Needing help with a turbo
Old Nov 9, 2011 | 07:07 PM
f1501987's Avatar
f1501987
Also selling a super chip max micro tuner
Old Nov 9, 2011 | 07:21 PM
f1501987's Avatar
f1501987
What kind of chip would anyone recommend all around? and ts chip or....... what
Old Nov 9, 2011 | 10:24 PM
Brown Falcon's Avatar
Brown Falcon
Most on here use either DP Tuner, or a TS chip with tunes from Power Hungry Performance, Tony Wildman, Gearhead, Beans, Tyrant Diesel... THey're all good programmers and can set up your chip settings however you want them.
Old Nov 10, 2011 | 07:11 AM
f1501987's Avatar
f1501987
i was thinking of the 6 stage ts chip,with 1. Stock 2. High Idle 3. 50hp 4. 75hp 5. 100hp 6. 140+
Old Nov 10, 2011 | 09:41 AM
Brown Falcon
Just realize that with stock injectors the most extra HP the chip can give you is about 60-70...
You need Stage I's to get up to 140hp added.
Old Nov 10, 2011 | 11:01 AM
f1501987's Avatar
f1501987
k thanks for info
Old Nov 10, 2011 | 11:32 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
I think they are good. Do you often Tow?
Agree with that. And you can ask to the seller of the chip that burns it for Stage I's even when you have stock sticks, works normally, and when you put stage's one you dont have to send the chip for a reburn
Old Nov 10, 2011 | 12:36 PM
f1501987's Avatar
f1501987
So if I buy a ts chip off ebay it will provide what it says for my truck. I have str8 pipe, afe filter. And whats a way to tell if the injectors aren't stock. My truck starts real easy in cold weather so I know the glow plugs are new.
Also how do you reburn it if I update my injectors after I buy it the way it is.
Old Nov 10, 2011 | 12:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Nope, you get the TS chip off e-bay and then send it to some one to do a custom reburn with your specs: stock, or some mods have you done like shift tranny kit, different turbo, etc, there you may want to say that you need the burn of the chip for sticks I's, even when you have now stock sticks, I hope I have explained myself.
Old Nov 10, 2011 | 12:54 PM
f1501987's Avatar
f1501987
Send it to someone like who? On the page for the TS chip they ask for the year,make,model, and tranny type. So I tell them all that, plus I want it for stock Injectors.
And were do I find the computer at(I looked beside the e-brake nothing there) my trucks a 97? and the PCM code, weres it at.
Old Nov 10, 2011 | 12:59 PM
f1501987's Avatar
f1501987
Iv read alot of reviews on the xtreme diesel, and they say it really helped alot even on stock trucks it turned the rear wheels over on 75hp setting
Old Nov 10, 2011 | 01:29 PM
Brown Falcon
You can run the TS tunes that come on the chip, which are ok... or you can send the chip to any of the tuners I mentioned several posts ago. Power Hungry Performance, Tony Wildman, Gearhead, Beans, Tyrant Diesel...
Or you can just buy the chip directly from one of them and save a little money.
Old Nov 10, 2011 | 01:52 PM
  #28
fordpride's Avatar
fordpride
i had xtreme diesel tunes for my first chip and their tunes suck my EGT's were high and a real touchy go pedal and trans **** like crap. i sent it in and had PHP tunes put on it and now getting BTS tunes put on it
Old Nov 10, 2011 | 04:40 PM
  #29
f1501987's Avatar
f1501987
Is a 6 pos Phoenix Chip good from powerhungry? Theres no offer for a ts chip, just a reburn offer
Old Nov 10, 2011 | 04:44 PM
  #30
f1501987's Avatar
f1501987
I need sites to look threw any one got any? Xtreme diesel seems bad? A phoenix is off of php, good choice? Im looking for a 6 Pos chip, that goes in like a TS, That changeable on the fly/or at a stop while started.
