Blend door problem 97 Explorer
Old Nov 6, 2011 | 09:18 PM
4.0 Beast's Avatar
4.0 Beast
Hey All,
A couple of days ago, when I switched from cold to warm air on the blend dial, it went warm but i couldnt get it to go back to cold. It stayed piping hot and wouldnt change at all. It didnt even blow cold when i switched it to normal or max a/c.
After reading the various posts on fixing the blend door, I'm not completely sure I have the same problem. My heat is on full bore, I can't even get the A/C to come on, not even in the MAX A/C setting. Most of the sites say that your MAX A/C should still be working. Do I have the dreaded blend door issue or could it be something else?
Thanks everyone...
97 Explorer 5.0
Old Nov 7, 2011 | 10:37 AM
4.0 Beast's Avatar
4.0 Beast
UPDATE -
I was able to get the a/c working but only once. I switched it to norm a/c from the off position and it blew semi-cool not cold like it normally runs. It is really cold outside if that matters, i dont know if the a/c was really kicking in or if it was just blending a mix of outside air and heat. And mind you i was only able to get it to do that once. It blows hot no matter what setting, vent (outside air), defroster, feet, any setting... and it doesnt matter what the temp slider is on either.
On a separate note - Every now and then when i fiddle with it, i can hear clicking noises coming from the dash when I play with the slider and move it back and forth a few times really fast, does this mean the actuator is bad?
Old Nov 7, 2011 | 11:43 AM
aquanaut20's Avatar
aquanaut20
Best bet is to slide your head under the passenger side of dash and see/listen.... Philip
Old Nov 7, 2011 | 12:35 PM
4.0 Beast's Avatar
4.0 Beast
I just took the glove box off and took a look under there but i couldn't find where the actuator is. I checked this website out but it doesnt really specify where to look:
The Last Resort Ford Blend Door Fix
This is the pic I took:
Any ideas?
Old Nov 7, 2011 | 12:51 PM
Surge08's Avatar
Surge08
I circled it
Old Nov 7, 2011 | 01:01 PM
4.0 Beast's Avatar
4.0 Beast
Ok thank you Surge! I suspected that was it, now hopefully its not too much of a pain to remove...
Old Nov 7, 2011 | 01:11 PM
Surge08's Avatar
Surge08
I think its a 5.5 mm socket possible 7mm
Old Nov 11, 2011 | 12:12 AM
jtsmith's Avatar
jtsmith
Trailering
The one in the back is the PITA to get out. 7mm socket
Old Nov 11, 2011 | 06:52 AM
4.0 Beast's Avatar
4.0 Beast
The directions just said to pry it off with a flathead screwdriver ?
Old Nov 12, 2011 | 11:36 AM
aquanaut20's Avatar
aquanaut20
That is Hillbilly method, saves buying sockets....... Philip
Old Nov 17, 2011 | 11:09 AM
alan_marks59's Avatar
alan_marks59
It depends on how it is attached. Some are snap on, some are bolted on.
GAC45
1997 - 2003 F150
18
Jul 6, 2023 08:50 PM
milmo1
1983 - 2012 Ranger & B-Series
Aug 1, 2004 12:51 AM
RWBlom
Apr 19, 2004 12:44 AM
rkasj
31
Jan 8, 2003 02:16 PM
stangz
Nov 21, 2002 10:52 AM
