1996 Bronco Intermitant runnning? Help
We have replaced:
-Distributer (it is the right one I know there is 2 different ones)
-Module: we have tried both black and grey one, it always had a grey one in it so we stuck with it.
-PCM
-Crank sensor
-New ignition swithch and ignition switch and box
- Neutral safety switch (even though it always cranked)
-Cap
-Roter
-Wires
-Plugs
-Coil
So as you can see we threw everything that we could thinkof at this problem..we think. Hence why we are coming to you guys. We have been thinking a bad connector, wire, fuel pump (but we intermitantly loose spark?)
We are at wits end and this is a plow truck that we really need to be reliable this year. If it is a bad connector or wire which do you think it may be? I have referenced this site for a few years now and have always had wonderful luck, please put in your 2 cents, any suggestion would be appresiated!
I have checked the codes, we keep getting a no spark code....I do not remember the exact code but will check in the morning and get back to you guys. The weird thing is since we put all the parts in it, even after it quits we do not get a check engine light like we used to? (not sure if that is a big deal or not) Do you guys know if a cam sensor could do this, not even sure the 5.8 has a crank sensor but we are really grasping for straws here! Thank you very much for your responces!!!
Have you tried feeling for hot electrical components after it shuts off? For it to randomly cut off, then start again after sitting, that definitely sounds like heat. Troubleshoot might be as simple as putting your hand on plastic parts to see if any are exceptionally hot.. problem is, it's usually a single wire or circuit that you might not be able to feel through the harness or housing of the part..
If it were my truck, I'd be at the point I would start suspecting stuff you have replaced. There was a guy on here that went through like 4 different distributors, same issue with each one, people kept on him about it being the distributor.. sure enough, eventually he found one that fixed the problem. A lot of the parts sold at these part stores are just flat out junk.
I know it doesn't help you much.. I will say though, distributor, ignition module and coil would still be my main suspects, even though they're new. What brand module, coil and distributor?
just be careful throwing money at new parts.. I'm on my 4th MLPS from Autozone..
It's a 96, 14 years old, it will not hurt at all taking off each plug you can get to, cleaning them, then putting some dialectic grease on and plugging them back in. You might as well, if you don't do it now you'll regret it later anyways.
Even on computerized trucks the ignition system is still pretty basic, it's still coil, module, distributor (uses magnetic pickup for timing still, if this is shot you'll get a no spark) and all the wiring in between them.
Think back, did any of the parts change anything when you replaced them? Make the problem more frequent or different in any way (like the check engine light) ? These stupid intermittent problems are not fun to troubleshoot, you'll think you have it fixed and then BAM, comes back and you're ready to pull your hair out.
could be so many things though.. your PCM might be at fault, just read about a guy that got sent the wrong PCM as a replacement and spent months troubleshooting it. I'd also check and recheck the harnesses, trace wiring from your distributor to your ICM (yours is mounted on the fender, right?), then to your PCM. All it takes is one short.
Something worth checking, my plug for my coil broke on me when I took it off and I didn't realize it, sort of a longshot but you should check it. The connectors were being pushed through the plug when I tried to plug it into the coil, I just removed them from the plug to plug each one in individually to make sure they were seated all the way. A lot of my plugs are doing this to me now and I have to make sure every single one of them contacts completely.
Also, check this out: 1983 Ford Bronco TSBs & FSAs (Recalls) for '83-96 Broncos & F150s picture | SuperMotors.net
found it while looking at other stuff and thought about your post, apparently I forgot to post it. I know 96' isn't listed, but trust me when I say some model years can be affected that aren't listed in the TSB.
Replace the dizzy and ICM, you should have warranties on the ones you have? The main problem with the no-spark in the dizzy is the ignition pickup, you can replace that by itself but it's sort of a pain to change.
Also check ignition wiring, that TSB should point out the ones you need to check.. very few things will cause a complete no-spark, even in computer controlled trucks.
Solid State electronics generally are bad off of the assembly line more often than they go bad after they're installed (PCM, ICM).
I was have intermittent stalling and no starts then transmission shifting issues. While the PCM was gone for repairs for the transmission issue I pulled my fourth "zone" distributor and installed a Motorcraft stator. One of those fixed the stalling problem and the PCM fixed the shifting problem.
