4R75E Fluid Exchange - FAIL !!
Old Nov 5, 2011 | 09:16 PM
xl1200c's Avatar
xl1200c
Unhappy 4R75E Fluid Exchange - FAIL !!
2006 F-150 5.4L 4x4 .. after researching forums i had everything ready to do a fluid exchange today. the return line on the trans is a bit hard to access so i decided to disconnect the return line at a junction block near the bell housing. thought it was a coupling used when the truck was manufactured. WRONG. when the engine started i sent an ATF shower across the engine, frame and plastic spill sheet. took me 2 hours to clean my mess.
undaunted i removed the 3 remaining lines from the block so i could get a good look. it seemed to have some sort of valve in it. i can't attach to the post so here is an external link to the pic:
http://surferlink.net/images/gizmo.jpg
doing my research tonight i find that the gizmo is a transmission cooler bypass valve. a good explanation is at this link:
https://www.ford-trucks.com/forums/8...ml#post7085959
oh well .. just a day wasted. tomorrow i get to try again. i am posting this so that anyone who is researching fluid exchange does not get the same bright idea that i had !!
Burrr
2004 - 2008 F150
Mar 20, 2017 05:18 AM
Flea
2009 - 2014 F150
Dec 11, 2013 08:08 AM
guessrow
2004 - 2008 F150
Sep 21, 2007 10:43 PM
scafes
Apr 3, 2006 07:03 PM
bboulier
May 25, 2005 03:01 PM
