IDM codes found??
Old Nov 5, 2011 | 05:38 PM
picassolawn's Avatar
picassolawn
IDM codes found??
Truck started running real rough, low power, shutters real bad. Could just be me but it seems like its using alot more fuel but i could be wrong on that.
im showing codes p1274 and p1316. I pulled the passenger side valve cover and checked all connections and wires. Everything looked perfect, connection was super tight.
I just started to pull the driver side and i can see that three of the wires going into the connector are exposed with the insulation falling off. They didnt seem to be touching each other or any metal but i could have moved them.
Could that be the problem? should i pull the VC and check the wires inside?
do i need to order a new harness for the topside or can i just liquid tape it?
any other things to check ?
all help is GREATLY appreciated
Old Nov 5, 2011 | 08:37 PM
F350-6's Avatar
F350-6
Wiggle the harness around a bit and see how it affects the truck. If you can hold the harness just right and the truck runs smooth, you might just be able to tape them up.
If none of the copper strands are damaged, tape should work fine. If some of the wires look too bad, a new pigtail may be in order.
Old Nov 5, 2011 | 08:41 PM
picassolawn
Im in the shop right now with it and tried that, didn't change anything. Good Lord that back VC bolt has me so mad!!
Old Nov 5, 2011 | 09:03 PM
F350-6's Avatar
F350-6
I feel your pain. That's the worst bolt of any on either valve cover. I think the passenger side is easier just because of that bolt. Just keep cussing the stupid Ford engineers who wouldn't make the truck 2 inches longer so there was actually room to work on it and you'll finally get it.
After your done, look here in the 6.4 section for pics of their motor and you'll feel better about the 7.3. Here's a pic a Ford diesel tech posted of how you have to work on the 6.4
Kind of makes that one bolt not seem so bad.
Old Nov 5, 2011 | 09:07 PM
picassolawn
Snuck a finger in, harness was loose as my ex. Runs great now
Old Nov 5, 2011 | 09:15 PM
picassolawn
Just when I finally get the socket on good the swivel blows out!!!!
Old Nov 6, 2011 | 07:01 PM
picassolawn
got the last bolt out and got a quarter in it. The truck runs better then it EVER has. It sounds different and just runs like a animal.
Skyrag
Mar 24, 2015 09:06 AM
chrisjrosenbohm
Feb 3, 2014 12:27 PM
cabloom300
Dec 27, 2012 04:55 PM
chris491
Apr 13, 2009 11:28 PM
DragnBotm
Jun 19, 2006 05:40 PM
