what custom fabrications have you done?
#47
#48
My last stock bumper had a hinge for lisence plate with winch to pull through.
This bumper I wanted all business so it's the reason I made the recessed lisence plate holder on tailgate.
Just in case anyones wondering the bolts on bumpers are for outrigger tubes that Attatch front and rear with ****** blocks and gives me the ability to use both winches to upright me in case of a roll over. Never needed to use but I've reinforced internals of bumpers to withstand the pull by lifting a heavy gas welder off the ground , about 1200 lbs.
Shackle holders unbolt to install a fairlead or cable would bind
Tubes interchange to either side so there's 2 in total
I run wireless winch remotes on different frequencies
I also run 12voltguy dash mounted winch controls
#50
Thanks, it's a piece of stainless. Difficult to drill as it's such a hard steel. Gauges are now installed. Messed up the wiper/headlight hole a bit, just need a platic edge to border it to hide and straighten out. I have green turn signal lights on there too. One is on the top left of the big hole. The gauges illuminate a neon green background as well..
#51
#52
Radiator Bottle
Want to keep this thread going so instead of doing a "Bump" i'll put in my modifications.
I put a very high tech overflow system in my truck.
First I spray painted the bottle black then I zipped tied it to the grille.
Drilled the hole in the top and put the hose in it.
(this is a pic of it zip tied to the hood latch because I have it all torn down. It usually is more to the pass side not in front of the radiator.)
#53
This has got to be one of the greatest mods I've seen in some time. Southern enginering at its peak.
Boomer
#55
#60
Me? I'm using a bunch of spare parts to build my truck. The fabrication comes in when I put them all together. When I'm done, I hope you won't be able to tell that I did anything.
Mods include:
GM power steering pump
4X4 conversion
'77 grill swap
raised front bumper mounts for the 3" body lift
engine mounts (cut 351/400M mounts down for my 300 six)
exhaust
...and not really fab work, but lots of rust repair.
Future plans:
rear bumper
bedside tool box
roll bar
Before:
After:
Mods include:
4X4 conversion
'77 grill swap
exhaust
Future plans:
rear bumper
bedside tool box
roll bar
Before:
After:
