Sponsored by: Real Truck
Automatic Headlights
Old Nov 4, 2011 | 05:42 PM
charbaugh's Avatar
charbaugh
Did any of the early 2000's SDs come with automatic headlights? I have a 2000 that I wanted to convert to ahve this feature. I found an after market module to manage the automatic functionality, but I wanted to see if any of the years had this as a factory option so that i could locate the factory switch that has all 4 positions.
Old Nov 4, 2011 | 10:10 PM
oldtechwiz's Avatar
oldtechwiz
2001 to 2012 have the feature standard I believe it was an option on 1999 and 2000. But I am talking 250sd xlt and 250sd lariat here. A Nice feature when it works, mine had a Multrifunction switch short and resulting fire and after that big trouble with main headlight switch microcontroller (computer) and it's related Security module.
Old Nov 4, 2011 | 11:11 PM
jc8825's Avatar
jc8825
I believe that it was an option much longer than the MY 2001. The 2004 XLT I had before my current truck did not have auto headlights, but my 2002 does. I still don't use it. I can decide when to turn my lights on.
Old Nov 5, 2011 | 01:37 AM
oldtechwiz's Avatar
oldtechwiz
You may be right, my dealer just said when I bought the truck that the LT version doesn't have the auto-headlight but the XLT does. In any event, I am removing it as I have already had I fire don't need another. If it matters, the fire issue is from a badly designed Multifunction switch which when it fails can cross wire headlights to signal lights to wiper control to 4 way flash. Returning my rig to non-auto and redesigning the multifunction is by far a cheaper, more reliable, and functional option for me.
Old Nov 5, 2011 | 02:22 AM
TRENT310's Avatar
TRENT310
'XL' trim package... it's not a GM product.
Also, auto headlamp control is part of the Advanced Security Group package now, not necessarily standard equipment on all trims. I didn't want to have a door keypad so I also don't have auto headlamps - all included in one package, which isn't a big deal.
Old Sep 25, 2016 | 05:46 PM
wilfreeman's Avatar
wilfreeman
And - he didn't! I hate that. Find a post that is exactly what you are looking for and the original poster doesn't end the post with an outcome. Oh well - keep on searching!
Old Oct 21, 2016 | 07:26 AM
wilfreeman's Avatar
wilfreeman
FYI, I ended up replacing my switch with one that had the automatic position (I did not want the fog light option, so I didn't order that switch), and installing the light sensor on the dash. The wiring plug for the switch was the same and the wiring for the light sensor was already there (clipped into the plug in the dash). Once installed, the automatic headlight and auto shut off functions worked WITHOUT having to have the computer flashed!
I bought my parts from Tasca, where they were MUCH CHEAPER than even eBay - $54 shipped.
Old Dec 14, 2017 | 10:41 PM
nickpohlaandp's Avatar
nickpohlaandp
Sorry for dragging up an old thread, but I just bought a 2012 F-250 today and I’d like to convert it to auto headlights. Would you mind giving a little insight as to how you did it, what parts I need? My truck is a base F-250 XL 4WD if that matters. No power windows or locks. Only real amenity is the CD player.Thank you very much in advance for any help you could provide
Old Dec 15, 2017 | 07:25 AM
wilfreeman's Avatar
wilfreeman
Hi Nick,
It's very simple. 1)Buy a light sensor and switch with automatic function. 2)Use a screwdriver to pop the plug in the top center of the dash out. There is a wiring harness attached to the underside of this plug. 3)Plus the harness into the light sensor and pop the sensor back in the hole. 4) Use a screwdriver to pop the access plate off the driver side dash to access the back of the light switch. 5)Plastic clips hold the panel (or switch) in the dash - carefully pry them up to release the panel or switch (I don't remember which). 6)Remove the old switch and replace with the new one. 7)Reinstall in the dash.
Mine worked first time, but I don't remember if that was after I had it reprogrammed for the brake controller or not (or if that would even have anything to do with it). So if yours doesn't work first time, you MIGHT have to have it programmed by the dealer (call them if it doesn't work).
Hope this helps.
Matt
Old Dec 15, 2017 | 10:21 AM
nickpohlaandp
Hi Nick,
Hope this helps.
Matt
So the parts I need are #3 and #15 (w/o dual zone) from the second picture on this page on Tasca (https://www.tascaparts.com/auto-part...omponents-scat)? I just want to make sure I’m getting the right stuff. Thank you so much for your help.
Old Dec 21, 2017 | 08:55 PM
nickpohlaandp
Extra, extra, read all about it. So I went ahead and ordered the following parts from Tasca. It was as simple as installing the light sensor and new switch and I now have auto headlights on my 2012 Super Duty. It took all of 5 minutes to install. Easiest vehicle modification I’ve ever done!
9L3Z-11654-DA
Headlamp Switch
$21.57
7L1Z-13A018-A
Sun Load Sensor
$15.95
Subtotal:
$37.52
Old Oct 26, 2018 | 12:20 PM
Chuck Atkinson's Avatar
Chuck Atkinson
i know its know it’s been awhile. But would u have the part numbers? I tried looking up and I couldn’t find one with auto headlights. Didn’t come with the harness and it was 140 bucks lol
Old Oct 26, 2018 | 07:02 PM
wilfreeman's Avatar
wilfreeman
I used 8C3Z-11654-DA switch and 7L1Z-13A018-A
Looks like Nick (previous post) used a switch with a different part #, but it must have worked also.
9L3Z-11654-DA
Headlamp Switch
$21.57
7L1Z-13A018-A
Sun Load Sensor
$15.95
Subtotal
$37.52
Old Oct 27, 2018 | 05:39 AM
Chuck Atkinson
9L3Z-11654-DA
Headlamp Switch
$21.57
7L1Z-13A018-A
Sun Load Sensor
$15.95
Subtotal
$37.52
awesome thanks. I have been looking to do this for awhile. Does it come with the switch plate? I’m guessing it does so it’ll have the auto headlights option
Old Oct 27, 2018 | 07:34 AM
wilfreeman's Avatar
wilfreeman
yeah, definitely a cheap, easy, worthwhile upgrade. The plate is part of the switch.
