Sponsored by: Real Truck
4x4 conversion
Old Nov 4, 2011 | 04:25 PM
93 mix 'n match's Avatar
93 mix 'n match
4x4 conversion
before i start, i know anything is possible with the right tools and a deep enough wallet. but im looking for simplicity.
im in the market for a diesel SD. i found one, but its 2wd. how hard would it be to swap in a solid front axle? i didnt look at it much, but i saw coils and radius arms, so i assume its like a TTB front suspension? can i just put a coil sprung axle underneath with minimal modifications?
Old Nov 4, 2011 | 05:21 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yes...no...yes
Some guys on here will tell you it's impossible, or not worth the work.
however, if you can grab a donor truck with a manual shift t-case, this is a very easy swap. The 4x2 and 4x4 share the same frame. so simply swap the stuff onto your 4x2 truck. attempting to do this using electronics will make it a nightmare...and probably impossible
Biggest detractors will be the trans tailshaft and driveshafts. 4x2 trans and 4x4 trans have different tailshafts. I've swapped them on Chevies before, but nobody on here seems to have done this...or at least admitted to it.
Also, you'd be old school and won't have a nifty 4x4 light on the instrument cluster.
Old Nov 4, 2011 | 05:47 PM
93 mix 'n match
well i know about the transmission. i just didnt know if the frames were different. so its pretty much bolt on? front suspension wise?
Old Nov 4, 2011 | 06:35 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Yeah, same frame. If you look on your current frame under drivers floorboard you'll see the holes in frame for where the radius arms bolt.
83capril
21
Jul 1, 2011 04:36 AM
Jon Hess
Apr 11, 2010 05:33 AM
93RangerXL4x2
Feb 28, 2010 01:13 AM
skymonkey
May 7, 2007 08:25 AM
ot2bhuntin
Sep 3, 2002 04:17 PM
