headlight switch
Old Nov 4, 2011 | 02:21 PM
72RichB's Avatar
72RichB
headlight switch
yesterday my new switch & relay arrived for my '72, quick question, what does the twisting action do?? pull out once is side & tail lights, pull again is main beam, but until I get my Chilton manual I need your expertise to explain for me, thanks in Advance.
Rich
Old Nov 4, 2011 | 02:29 PM
koch26's Avatar
koch26
twist to the right dims inside lights twist to the left brightens inside lights and twist it far enough to click turns on your dome light.
Old Nov 4, 2011 | 03:31 PM
72RichB's Avatar
72RichB
Thanks Koch, just need to work out how to dismantle it to swap in the new one
I'm loving this truck
Old Nov 4, 2011 | 03:40 PM
koch26's Avatar
koch26
Its pretty easy I think you just unscrew that trim piece
Old Nov 4, 2011 | 04:29 PM
72RichB's Avatar
72RichB
thanks, will have a look tomorrow when it's not raining
Old Nov 4, 2011 | 04:45 PM
koch26's Avatar
koch26
I had bought a switch and it was from Napa and it was the wrong size it really didn't make any sense at all it was like almost missing parts or something. So I just ended up cleaning the corrosion and still a year later it works just fine
Old Nov 6, 2011 | 05:09 PM
orich's Avatar
orich
Aw yes the metal piece on the front tack welded acts as a spacer. I got it separated then JB welded it on the new switch and good to go..my 2cents.
orich
Old Nov 6, 2011 | 06:07 PM
72RichB's Avatar
72RichB
ok, thanks, will have a look at that.
Old Nov 6, 2011 | 06:18 PM
tmcalavy's Avatar
tmcalavy
Eventually the little rheastat in the switch will crater and you will lose the dimming function. To remove the switch, you push in on the tab/button on the body of the switch (behind dash) and pull the handle and shaft straight out. Then you can remove the dash bezel and replace the switch. Then depress the tab/button again and put the shaft/**** in the new switch...Bob's yer uncle.
Old Nov 6, 2011 | 06:27 PM
koch26's Avatar
koch26
I usually leave it on max brightness I don't see anyreason to dim your lights but to just say you can
MichiganLarry
Jan 27, 2016 06:27 AM
1992FordF150Custom
Aug 28, 2014 01:17 PM
F350moneypit
Jan 17, 2013 08:29 AM
myv-879
Jun 25, 2009 07:41 PM
slimfitz
Nov 26, 2005 07:06 AM
