What's your F350 GVWR?
Hi guys,
If / when the time would ever come, I'd want to go from my F250 to an F350 4x4 CC SRW and highest GVWR I can get. I see quite a few possible options for the 2012, from 10,700 to 11,500. If I read this right, the GVWR for this truck would be 11,500?
Thanks ya'll
Thanks ya'll
For the record, the only mechanical difference between the F250 and F350 SRW trucks is the rear spring pack and the 2" taller rear blocks. And if said F250 has the camper package the spring pack is identical.
I wouldn't buy another truck for the increased capacity. Much cheaper to just buy a set of airbags!
Hi guys,
Thanks ya'll
Thanks ya'll
1. Go to www.fleet.ford.com.
2. Select "Showroom", "Truck Bodybuilders/upfitters"
3. Select "Publications", and then "Vehicle Specifications"
Looks like you're right though, the F350 SRW diesel trucks do have hydroboost brakes. The gas SRW trucks have vacuum boost. I get a little confused sometimes because my 2008 F250 had hydroboost brakes.
Attached is the specs sheet for 2012.
I don't really see why. I recently had the pleasure of driving 2000SilverBullet's 6.2L truck. The vacuum boost brakes were easily capable of locking all 4 wheels while loaded down with 2,000 lbs tongue weight. The GVWRs are within 200 lbs of each, and so I would say that the vacuum system on the SRW trucks is every bit as capable as the hydroboost is.
Originally HydroBoost brakes were on diesel trucks because there is no manifold vacuum to power a brake booster. I guess in recent years they decided it was cheaper to mount a vacuum pump.
