engine missfire at higher speeds
Old Nov 4, 2011 | 10:51 AM
cadetspider06's Avatar
cadetspider06
Question engine missfire at higher speeds
while driving the truck the motor will lose all power when I give it the go pedal. I had no problems this morning but on my way home it started to do this. When I speed up from a light or stop sign, it feels just as powerful as normal.
It will not die, I just cant give it more than 1/4 throttle. If I take it out of gear it idles great. The truck slows down to about 30 and then regains power. Its an intermittent problem and I am stumped.
88 1/2 4.9 I6 fuel Injected
Old Nov 4, 2011 | 02:42 PM
njneer1's Avatar
njneer1
Maybe fuel pump
Old Nov 4, 2011 | 03:39 PM
cadetspider06
Would the fuel pump fail and then work and then fail again?
Old Nov 4, 2011 | 04:34 PM
AbandonedBronco's Avatar
AbandonedBronco
If the pump is weak (or the filter is clogged) it won't be able to deliver the fuel required at higher speeds or under high load conditions, but will be enough to keep the engine running when it requires less fuel (cruise/idle).
Old Nov 4, 2011 | 05:44 PM
cadetspider06
Ok I bought a new filter on my way home and will change that shortly.
When I moved the truck from the front to the garage, the fuel pump priming sounded like it was full of rocks (it sounded really bad)
Old Nov 4, 2011 | 07:02 PM
njneer1's Avatar
njneer1
not a good sign.....you might have found the problem
Old Nov 4, 2011 | 07:57 PM
cadetspider06
Ok. new filter installed and now it will not start at all
Off to pick up the inline pump
Old Nov 4, 2011 | 09:14 PM
cadetspider06
Ok. New fuel filter, inline pump, still runs like crap.
front cat gets hot, second not so much, but i didnt drive much (because it runs like ****)
Possible clogged cat??
Old Nov 18, 2011 | 06:44 PM
cadetspider06
OK. New inline fuel pump, in tank fuel pump, and throttle position sensor.
It runs good until its warmed up, then will not run at all.
I am all out of ideas
Old Nov 18, 2011 | 09:53 PM
1983F1503004x4's Avatar
1983F1503004x4
It's an 88?
Ask the computer what it says is going on.
Fordtrucks123456789
Jun 3, 2015 08:53 PM
'88 E-350
Jul 25, 2010 02:35 PM
76CamperSpecial
20
Nov 9, 2008 12:49 PM
87longbed150
Mar 24, 2007 09:14 PM
Cecil501
18
Jul 14, 2006 06:53 PM
