Lifter pre-load question
Old Apr 11, 2003 | 12:31 PM
chissler's Avatar
chissler
Question Lifter pre-load question
Does .060" lifter preload sound good to you guys? I am using the shortest pushrods available: 9.56". I know .030" is optimum. I've heard .020-.040 is acceptable. Do I need to get custom pushrods or will these ones be o.k.? The valve lash is within Ford specs, but it's on the edge.
Old Apr 11, 2003 | 09:56 PM
dinosaurfan's Avatar
dinosaurfan
Chissler, part of the reason why I like adjustable rockers, even on a hydralic cam, is that I can set the lifter preload were I want it. I like .000-.020 on a hydralic cam. Assuming you're stuck with normal rockers. and if you have the shortest normal pushrod, how did you end up with .060 ? Have your heads been milled ? block decked ? Do you have your oil dripshields on underneath your rockerstands ? DF
Old Apr 11, 2003 | 11:26 PM
chissler's Avatar
chissler
Yes, everything is installed correctly. block and heads have been milled. After paying for everything else, I cannot afford adjustables. Is .060 too tight?
Old Apr 11, 2003 | 11:30 PM
Ratsmoker's Avatar
Ratsmoker
.060 is considered max I do believe. I like to run mine pretty loose like DF does. I just go a quarter turn with mine and that's it.
Buyerz
Jun 19, 2016 10:27 AM
BaronVonAutomatc
28
Apr 2, 2016 05:16 PM
thatguy71
Feb 19, 2015 09:54 AM
thatguy71
May 28, 2014 01:02 PM
TheImpaler
13
Feb 20, 2004 04:33 PM
