VIN Decode Request
Old Nov 3, 2011 | 03:44 PM
turpehar's Avatar
turpehar
VIN Decode Request
I have a 1979 Ford F250. I would like to have the VIN decoded. Here is what I have.
From the Door
VIN F26HUFC3003
WB 133
Color OA
Type F263
Body BDY
Trans K
Axle B4
1979 55
F0055
T0656
Carb believed to be Motorcraft 4350
D7VEAAA
A 7F 17
Carb kit 910C I think
The motor appears to be a 351M. The PO had the carb half apart on the vehicle. I pulled it and cleaned it a bit and bolted it back together just to see if it would fire. The only way I could get gas into the carb was to go through the vent hole. It fired up right away but as I thought fuel exited the bowl vents so I shut it down.
If connected to the fuel filter nipple, gas would not pass even though the filter itself was missing. Since I didn't have one I put a nice in line filter in. I assume the float is stuck shut.
In addition I did notice that the intake was an Edelbrock Performer square bore, so the idiot PO had no idea what he was doing as the 4350 of course is a spread bore. So the secondaries will never open.
Thanks
Old Nov 3, 2011 | 07:53 PM
devino246's Avatar
devino246
F26- 4 wheel drive pickup (F250)
H- V8, 351m, 2-bbl 5.8L
U- Manufactured in Louisville
OA- Silver Metallic/Black
K- 3 speed Automatic
B4- 4.10:1 gearing, 5.3M, Dana 60 (Spicer), Limited Slip
jkalin99
Large Truck
Feb 2, 2019 08:55 PM
hymanje
Large Truck
Aug 11, 2016 09:03 AM
spikinfool05
Feb 10, 2012 10:40 PM
cipsmithers
Nov 29, 2008 03:27 PM
ford_nut
Jan 31, 2002 12:22 AM
