please help
Old Nov 2, 2011 | 06:23 PM
joellaw's Avatar
joellaw
please help
i have 2005 f250 6.0 diesel between 1500 and 2000rpms it starts missing bad i put a new ficm and a egr vale in it.It still missing what can it be pleaes help
Old Nov 2, 2011 | 06:30 PM
zhilton's Avatar
zhilton
Not knowing the history of what you've done (beyond what you listed above) I'd get the codes checked/pulled before I went much further. It could be low fuel pressure, clogged filters, bare wire, bad connection....the list goes on. Need a little more information to be of much help. You might see if your local AutoZone has a ScanGauge II they use for checking "check engine lights"...or you can pick one up for $160-ish; not a bad investment for a modern truck/car.
Old Nov 2, 2011 | 06:37 PM
BLADE35's Avatar
BLADE35
X2
Couldnt have said it any better
alittle trouble shoot would go along ways throwing parts at stuff gets expensive quick
Old Nov 3, 2011 | 12:46 PM
steven06's Avatar
steven06
Getting a scanguage will help greatly. Does it do it in gear only or in nuetral as well. With diag equipment (scanguage) you can check the ICP, high pressure oil, and the IPR duty cycle, tells you what the IPR valve is doing, that sends the high pressure oil to the injectors
Jxltrucking
Mar 15, 2017 01:56 PM
ToolmakerRob
Jul 12, 2016 10:27 PM
Will Bite
Sep 16, 2012 08:14 AM
castroke#1
Nov 20, 2010 07:29 PM
jchase23
Oct 31, 2010 09:04 PM
