TowBoss??
Old Nov 2, 2011 | 09:41 AM
steven06's Avatar
steven06
TowBoss??
I recently purchased an 06 F350 CC DRW with the towboss package. I know that this has 4.30 gears what else is included in this. Is it just a finned aluminum diff cover or is a different axle. Does this mean that my axle weight would be the same as a F450. I have heard it told both ways that it is just lower gears and a cover, or that it has F450 running gear to include brakes. Thanks for all your incredible knowledge.
Old Nov 2, 2011 | 11:19 AM
Rusty Axlerod's Avatar
Rusty Axlerod
I rooted around a pretty good bit and still can't directly answer your question. Here is some good info though, if you haven't seen it.
Late in the 2005 model year, Ford came out with a new option for F-350 DRW pickups. It was called the TowBoss pkg. It included a beefed-up rear axle with a 4.30 axle ratio, and that increased the GCWR by 2,500 pounds to 26,000 pounds. But that was a fairly rare option.
Here is an interesting old thread about the tow boss:
https://www.ford-trucks.com/forums/s...d.php?t=398751
This is direct from Ford's website.*
Maximum Trailer Weight= 18,300#
Gross Combined Weight Rating= 26,000#
Gross Vehicle Weight Rating=13,000#
No Tow Boss Pack.
MTW=15,600#
GCWR=23,500#
GVWR=13,000#
The Towboss Pack. must be ordered with a 6.0 diesel, and auto trans. It is only available in an F-350 DRW config. It includes the trailer brake controller and mirrors. You can order the Tow Command System which is everything except the 4.30 gears. Second set of figures is with 4.10's.
Old Nov 2, 2011 | 11:41 AM
PowerStrokeHD's Avatar
PowerStrokeHD
'06 Tow Boss Package (53B) - MSRP $715.00
Optional on all F-350 DRW Pickups.
Requires - 6.0L Power Stroke Diesel Engine (90P), TorqShift Automatic Transmission (44B) and TowCommand System (91T).
Includes - 4.30 Limited Slip Rear Axle. Increased GCWR to 26,000 lbs.
Old Nov 3, 2011 | 10:15 AM
steven06's Avatar
steven06
Thanks all for the info wasnt sure. My biggest question was if the axle is allowed more weight 12k as opposed to 9k
internetgardener
Nov 16, 2024 09:54 AM
toymaster
Jul 16, 2023 01:27 PM
Floridatex
Aug 1, 2013 07:32 PM
steven06
All Things Towing
16
Nov 4, 2011 08:59 PM
Gary E K
All Things Towing
Jan 16, 2003 08:49 PM
