Ok here it is lastnight i changed my fuel filter put a new one in filled up the bowl with fuel then slowly put the new one in tighten down filter cap started it up ran good then shut it off then let sit for couple mins then started up again no problem then let sit alnight plugged in wife went out to start it this morning started up fine ran for couple mins then died tryed to restart but not starting its acting like it wants to start but wont start its cranking fine. what did i do wrong wifes mad at me please help also on the same note the wts light comes on also the fuel in water light comes on. what is a idm where is that and what name goes with it . also what is a icp i have been researching all day its driving me crazy please help its a 1996 ford f350 powerstoke ok here it is finally fixed my truck after all info u guys gave me i tried ever thing that was supplied to me in info heres the kicker make sure the fuel guages work right i thought i was full on the rear tank but no was empty all alone i feel like a dumb *** big time filled up tank bled out system well what u know its runs so all u people out there thanks and some of u guys with no start check gas tanks i learned a very costly lesson ps i just got the truck to so i didnt think to check that
Reason: update
Big. Did you change the filter while the motor was cool? There is a rubber "O" ring on the filter that has to "seat" right. Also is your drain closed? Is there fuel comming out around the filter? This would tell me that it is either not tight,cross threaded, or the O ring did not seat correctly. It sounds like you might be getting air into the filter. Not a mechanic just prior lessons learned here. Good luck.
IDM = injector driver module. The PCM tells the injectors when to fire via this. ICP = injector control pressure...pretty self explanitory. Here is a thread about the WIF light
Is the fuel bowl still full? IDM is injector driver module, it fires the injectors. Located on the drivers inner fender. ICP(located on drivers side head towards the front off the side of the fuel pressure regulator) is read by the PCM (computer) and tells the IPR (injector pressure regulator located on backside of high pressure oil pump) what it needs for oil pressure based mainly on the tps(throttle position sensor).
Did you clean the screen in the fuel bowl? How much cranking have you done? Checked the hpop resevoir?
i made sure oring is right no fuel leaking and changed fuel filter while some what warm
the fuel bowl is not full but 1/4 way full not all the way
the fuel bowl is not full but 1/4 way full not all the way how do u clean screen?
With the filter out on the drivers side down about an inch, take a qtip and pull the cotton off and clean it off with that.
Fill the bowl and try again. If you've done a lot of cranking check the hpop, it can drain down with excessive cranking. Make sure batteries are fully charged of course.
how to check and fill up hpop and whats that? i have redid the fuel filter two times refilled up bowl and reinstall it still the same way
If the engine stalled , either the fuel pressure went away or the hp oil pressure ... Check the oil ...Are the tanks full ? If you have a no start , try unplugging the ICP sensor at no start .. After that , we are going to need some live data...
